Traction 4-wheel Drive
/ 4-wheel Drive #1
toneychaney
kioti ck20
I have a Kioti CK20 and It will not go in 4-wheel drive at times and others times it will not stay in 4-wheel drive, can someone help with this problem? I tried to use the bucket and raise it up and then try to get it in 4-wheel drive but that does not work, at times it will go in 4-wheel drive when it is in the HI gear but won't when its in LOW gear with it not going in 4-wheel drive there is a lot of things I am unable to do with the attachments, Please help.
toneychaney@comcast.net
/ 4-wheel Drive #2
I believe that the 4wd lever is mounted on the same shaft as the High-Low shifter. You need to lubricate all the linkage as well as the pivot points on the shaft..
UNUSED KUBOTA BRUSH GUARD PART (A62130)
UNUSED KUBOTA...
Freightliner Tender Truck - Adams Tender (A63118)
Freightliner...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2002 Godfrey Sweetwater Pontoon Boat (A61166)
2002 Godfrey...
New/Unused Wolverine Quick Attach Auger (A61166)
New/Unused...
20 Yard Roll Off Dumpster (A61166)
20 Yard Roll Off...
