Backhoe Trying to put BH back on
/ Trying to put BH back on #1
jsmk
Kioti CK30HST
I took my BH off for the first time a few days ago to tryout my PHD. Now I tried to connect the hydraulic lines from the BH to the tractor and I am unable to get them connected. I slide the retaining ring back to put the line in but I can't get it to go far enough to lock. So far I tried it with tractor on and off, made sure all hydro stuff was resting, and tried moving the AB lever in different positions.
I haven't read about this in the forums yet so figure it must be something simple that I just don't know yet.
Help a guy out with a stupid question and I'll try to only ask it once.
This is a Kioti CK30HST.
Thanks
/ Trying to put BH back on #2
You may have developed pressure in lines, was it out in sun or hot weather? Take a rag and a small drift pin to push in on center ball to relieve pressure, make sure you use rag so Hyd fluid does not hit you or eyes, then retry connectors, good luck but that should do it.
DevilDog
/ Trying to put BH back on #3
DevilDog
I have had the same problem. I have used a hammer, again make sure you put a rag over the end as suggested by devildog1, and give the end of the hose fitting a tap with the hammer. You are trying to relive pressure that may be present. I also put colour tape on both hose and tractor fittings so you don't have to try and guess which hose goes where. Good luck in getting the fitting to work. :)
  • 670DecemberPics 104.JPE
DevilDog
That is kind of what I was thinking with the other things I tried, but I was a little nervous pushing anything in there. And yes last two days have been pretty **** hot.
Thanks
/ Trying to put BH back on #5
It's not a stupid question. I remember asking the same thing on here. The method I use is a pair of channel locks and rag. I've removed and mounted my BH 20+ times leaving it sit in various ways and 90% of the time, it's gonna have pressure on the lines. Good luck.
/ Trying to put BH back on #6
I would be very careful of pushing anything in the middle of the connector.
If the fitting is on the correct connector, (should be easy) and you slide the ring Bach and push the connector it should go in, PERIOD !
The engine should be shut down.
If this continues you should find why it is happening.
OK, now I do not own Kubota but my CCY has never had this happen.
If I take off the BH the stabilizers are usually down and the BH extended some.
Luck
Mousefield said:
I have had the same problem. I have used a hammer, again make sure you put a rag over the end as suggested by devildog1, and give the end of the hose fitting a tap. You are trying to relive pressure that may be present. I also put colour tape on both hose and tractor fittings so you don稚 have to try and guess which hoes goes where. Good luck in getting the fitting to work. :)
I got it without much problem and had no further trouble putting the BH on. Maybe ten minutes tops.
I dug out a couple rocks, but when I turned around to move them I noticed I broke the el shaped brackets directly behind the FEL. I had previously bent them when one of the pins forward of them fell out. By the time I noticed the pin was missing I have bent them. Now thru are broke. I guess I need to be more careful. I don't want the school of hard knocks to become too expensive. The guy at the dealer said some people weld stiffeners on them. I might get that a go.
/ Trying to put BH back on #8
I have tried the channel lock pliers method as well, worked but like the hammer method a bit better. :)
/ Trying to put BH back on #9
Luck
It seems to be fairly common to have trouble getting the hoses back on due to pressure build up. Until you can relive the pressure it's almost impossible to get them back on. Just saying :)
/ Trying to put BH back on #10
I experienced the same issue and simply loosened a hydraulic connection on the backhoe. Then worked all the levers to relieve pressure. I havenen't made this mistake again.
/ Trying to put BH back on #11
I have had this happen. To prevent the pressure problem I shut the remote valve down after and then move the two big sticks to all four positions. The next step is to block up the backhoe which I sit on four furniture dollies This seems to bleed the lines of pressure and eases reinstallment of backhoe.
Can somebody explain to me in a little more detail how the hammer is used to release the hydraulic pressure from a line? I can't imagine banging on a coupling with a hammer. I did not know how much of that those couplings can stand. Thanks in advance for any tips.
rimshot
/ Trying to put BH back on #12
rimshot
After putting a rag over the end of the hose coupler I TAP the end. I may have to do it a few times. There is what looks like a slightly raised ball in the middle of the end, all you need to do it have it go a bit down and the hydraulic fluid under pressure will squirt out, it only takes a little bit to be successful. I am not banging or whaling away at it and having the rag over the end you are not damaging it. Most of the time I don't have to do this as I do like you, move the different backhoe cylinders to relive the pressure. :)
/ Trying to put BH back on #13
Agree with Mousefield's method. I carry a small tack hammer in my tractor for just that purpose. Paper towel or rag necessary both to prevent mess and to protect the nipple. I also carry a 2" 3/8 bolt which I use to insert in an uncooperative female fitting then tap on the bolt head the same way. Rag in that case is just covering the outside of the fitting so the oil doesn't squirt back at you.
/ Trying to put BH back on #14
I guess I've been lucky with my CK30hst and KB2375. If they won't conect at first, I just move all the bh controls and the pressure equalizes somehow and I can connect the QDs.
I had used the hammer and rag method the first time I had these problem and it worked pretty good.. It was a tad harder to connect then I thought it should have been but I got it on ok. Well I used the PHD again and when I went to put the BH back on no amount of hammering would work. I remembered someone mentioned channel locks, so I gave that a try. Piece of cake. It only need slight pressure on the pliers to get the hose pressure down. Then connection was easy.
It is nice to have a place to get questions answered.
/ Trying to put BH back on #16
Ditto for me, just move all controls including the remote levers.
hugs, Brandi
/ Trying to put BH back on #17
First three years I removed the BH for the winter... no issues in the spring putting it back on. This year I took it off later in the fall and put it on later in the spring, big temp difference I suspect. I couldn't get he fittings connected no matter how much I pushed and prodded. I moved all the controlls on the BH, numerous times, still no go. I then put the rag over the connector and hit it with wooden handle end of my hammer. I figured the wooden handle would be less likely to damage the ball. I must have hit it 10-15 times, got a real good squirt the first few times... real glad I had the rag over it. Finally releved all the pressure and they went together fine. I too have managed to get rocks and junk in the brackets on the tractor making it real difficult to get the BH fully seated and the pins in. Finally wised up and I make sure they are all clean before I back up to the BH.
/ Trying to put BH back on #18
or...wait till very very early in the morning, as the fluid will have contracted and pressures will have dropped. then try hooking them up again. I learned years ago to only leave an unattached hydraulic line in the shade.....or carry a hammer and a rag when i go to hook them up. it does get kinda messy though.
/ Trying to put BH back on #19
I got these pliers from an ad in 'Farmshow' - they were around 35$ with shipping. They are fast and easy and make relieving residual pressure a painless deal - they have different sizes for different size couplers. Fit in CK-20 toolbox. ...... the tool works like a pliers to grip the coupler and you release the pressure with the screw. The address they give is George Waite, Waite's Tools, PO BOX 66, Atwood, Colorado 80722 The phone is 970-522-5696 .......
/ Trying to put BH back on #20
Clever idea and I'm sure it works. A bit more expensive than a tack hammer and rag though.
2022 Bautista Welding and Custom 40ft. 10 Ton T/A Gooseneck Flatbed Trailer (A61573)
2022 Bautista...
2015 Nisan Altima S Sedan (A61574)
2015 Nisan Altima...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63276)
KNOW BEFORE YOU...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
