Mowing john deere 950 power loss
/ john deere 950 power loss #1
daw1211
john deere 950
I have a john deere 950 i bought about a year ago. runs and starts good but after abount 1/3 hour or 45 minutes of heavy use at full throttle, it looses power. changed fule filter, oil, and oil filter. air filter looks good but will change next. No smoke of any kind. It doen't seem to be hot but can't be sure ( no bubbling or steam). checked hot warrning system by grounding wire to fram and turning key on ( light came on). Help!
Thanks!
/ john deere 950 power loss #2
Thanks!
Check tank vent by running the cap lose. Also change both air filters assuming yours has a double elements. Make sure you don't have debris in the tank that can plug the line.:thumbsup:
Does it have a mechanical/electric supply pump. The electrical ones can be tricky to diagnose as they can run normal and appear to supply fuel but quite when under load.:(
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
KMC 3386 (A64119)
KMC 3386 (A64119)
2019 CATERPILLAR TL642D TELESCPOPIC FORKLIFT (A62129)
2019 CATERPILLAR...
2008 Case IH 2152 Combine Header (A63688)
2008 Case IH 2152...
2016 Chevrolet 2500 HD 4WD (A63689)
2016 Chevrolet...
