Mapp gas
/ Mapp gas #11
If your concerned about extra work, it's interesting your making repairs to galvanized metal with solder, in the first place. .
since I'm not made of money and can't go out and buy a new set of water tanks every time a hole opens up.. then.. well.. that means I have to repair them. so far.. the BEST repair I have used has been solder.
I've tried rtv on the inside.. that lasts 1-2 seasons, then lifts.
I've tried epoxy.. that lasts 1 season exactly, till winter happens and the metal slightly deforms betwqeen the 30' swings between night and day, and the epoxy cracks or pops loose.
as of yet.. I've -never- had to re-repair a solder patch I've done..
here's my own disclaimer... I've been soldering for decades.. and I'm good at it..I solder alot.. and get lots of 'practice'.. results may vary based upon the solder's skills.. that's a given.
I've also not tried multiple types of epoxy's and sealants. I used a couple rtv types.. and a couple epoxy types.. liquid mix in set type and a putty type.. since I had poor results I decided to stop expirementing and do something I knew would work, and would be cheap ( cheapest epoxy set I know of is at least 5$ ).. vs a few inches of solder and a few swipes of a brush with some flux.. IE.. pennies or maybee nickles considering the amount of repairs I can get out of a tin of paste flux, a roll of solder and a tank of hot dog gas.
With a well and float valves on water tanks at a remote property I can't afford to be gone a week and come back to a swamp because some jb water weld putty failed when the tank got cold, then constantly leaked and ran my pump for a week .. wetting everything down and running my electric bill thru the roof. I have to fix em and trust the fix.
I'm sure there is some wonder flexible glue-goo out there I'm not aware of...
I now know all those who use hydrochloric acid, nitric acid, sulfuric acid, muratic acid, etc, to eat the galvanize up, (read the thousands of hits you will get in a google search of this topic), are all wrong, (my self included), and it is all unnecessary, if we just use Wal Mart flux.
Thanks for the help.
that little pout added nothing positive to this thread... :(
soundguy
/ Mapp gas #12
FWIW...I have used regular (old) lead/tin plumbers solider to make skylight curb flashings with galvanized angle flashing...with just plumbers flux and propane torch...works great...
I have also fabricated chimney caps with galvanized eaves drip and galvanized sheet metal using plumbers solider...
excess flux should be removed...
/ Mapp gas #13
back in the day when radiator tanks were actually metal and you could fix them.. vs the composite ones.. my favorite patch for a pinhole was a penny.. flux it and solder.. I would usually grind one side down flat to make it fit better.. even worked when they went to the hi zinc content pennies. never had a lick of trouble wetting zinc.
soundguy
/ Mapp gas #14
Surprised to hear that regular solder would work, good to know. Back in the day when there was a living in it a good friend operated a rad repair shop, was amazed what he did with propane / compressed air and a 50 pound spool of silver solder. Would watch him pop the tanks off the old rad, clean them up, install them on a new core and pressure test it in under 5 minutes, was something to watch.
I too questioned the strength of silver solder, given the stresses a rad endures installed in a vehicle. He silver soldered two pieces of brass together and offered me the opportunity to pull them apart, with a hammer and a chisel. Needless to say I became a believer pretty quick.:laughing:
/ Mapp gas #15
Yep- 35 years ago I was on a maintenance crew at a college. We routinely soldered end caps and downspouts on galvanized gutters. Old school technique..we had big 5 lb copper slug soldering irons that were heated on a burner then applied to the gutter with regular old paste plumbers flux and a big ole bar of solder. In fact you didn't want the galvanizing off...plain steel is a lot harder to solder:thumbsup:
/ Mapp gas #16
ever see a double bbl shotgun? see the bottom and top ridge covers.. now look at the bbl end.. the grey metal between the bbl's and ridge covers is silver solder :)
the oil pump pickup tube on an old fors is silver soldered into the pump whish is on the crank bearing cap...
solder is good stuff for those that know how to work with it and given you have an appropriate application.
soundguy
/ Mapp gas #17
ditto that too... also.. when soldering.. I'd prefer to solder cast iron vs steel.. easier to wet. perhaps the specific allow adds? ( copper, nickle.. etc.. ) ??
soundguy
/ Mapp gas #18
My point was directed to those who were concerned about the fumes generated using a torch on galvanized steel.
I've welded on galvanized steel with never any problems from the fumes. I'm either outside or if I'm inside, I've got the shop exhaust fan going and I position myself to stay out of the smoke. The big problem welding galvanized steel is getting zinc into the weld, zinc will weaken the weld, make it porous, etc. Using any powerful acids on steel will introduce more cleaning issues, because rusting will be accelerated on steel that's had contact with acid.
/ Mapp gas #19
soundguy i might try that soldering with map gas on a tank .i usually would just braze it.mapp would be a lot more portable.i think brazing would be stronger,but since i have never soldered on a stock tank what do you think?
/ Mapp gas #20
Depending on how much strength you need. Brass Brazing rod works real well on Zinc. If all you need is a seal lead solder works well.
I have stick welded it using 6011 by using a stop & start method. Weld about 1" , stop give it a little time to cool and go again.
Should you get too much fumes in your lungs, drink a lot of milk and it will flush your system.
2005 SHOP MADE MANIFOLD TRAILER (A60736)
2005 SHOP MADE...
2019 BOBCAT T740 SKID STEER (A62129)
2019 BOBCAT T740...
2014 FORD F-550 XL SUPER DUTY SERVICE TRUCK (A59823)
2014 FORD F-550 XL...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
1995 HEIL  ALUMINUM TANKER TRAILER (A60736)
1995 HEIL...
Giyi Gy-BK56 QA Backhoe (A60463)
Giyi Gy-BK56 QA...
