PTO
rogatkinson
Massey Ferguson 135
Can anyone give advice re. fitting seal around PTO shaft to stop leaking oil.
Cheers
Roger
Cheers
Roger
On what tractor?
You might want to check for loose bearing. If not, remove seal, look at shaft to seal mating surface. Look for worn surface. If not, simply replace seal and go.
/ PTO
Hi Farmwithjunk
The tractor is a Massey Ferguson 135 Diesel.
Thanks
Roger
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2022 EZ-GO ELITE...
2011 FORD F-350 FLATBED DUMP TRUCK (A64278)
2011 FORD F-350...
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A64280)
1994 CHEVROLET...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
