Dirt Scoop - the next best thing to sliced bread
   / Dirt Scoop - the next best thing to sliced bread #1
Daryl Greene
Yanmar F22D
... at least for those that have major budget limitations. Recently I purchased a Yanmar F22D and, as a demonstration of my wife of how desperately I needed this tractor, I chose my first project. I had a dump truck load of topsoil delivered (22-24 cubic yards) yet I needed a medium to move this dirt throughout our property. A front end loader, although highly desirable, was simply out of our means. I researched this site as well as others and decided that the dirt scoop made the best sense providing that it could deliver as designed.
I sought out this scoop AFTER the mountain of dirt was delivered in our front yard. On Craigslist I found a very vague description of a "LIKE NEW POND SCOOP;PUSH OR PULL" I drove out and saw what I considered to be a massive 30" King Kutter Dirt Scoop. Initially, I did not believe that this beast would even fit on my F22D. I expressed my concerns to the seller and then I requested that he hook this up to his Yanmar YM2000. He did, it fit, I paid (on the cheap!), and we loaded the scoop into the back of my truck.
I started this project rather enthusiastically while gingerly backing up to my dirt pile while gently raising the scoop. The scoop held some dirt!!! I got off of the tractor and manually released the dump lever for the first couple of loads. During my research, I remember seeing that others had rigged up a pulley system that enabled the driver to release the latch while seated so I searched my shed and came back with two pulleys, a length of rope, and an impromptu handle (a wooden dowel which I cut a groove in midway in the length). I rigged this up and went to work moving dirt!
My neighbor moseyed over yesterday to investigate the contraption he had seen me maneuver over our plot of land and he too was impressed. I finished moving the dirt pile this morning and I am extremely pleased by the ease-of-use and performance of the 30" King Kutter Dirt Scoop. I did reverse the scoop to scrape and it did fine but my technique is lacking.
Now, switching gears, I have a more philosophical question to pose. During my search for 'intelligence' regarding dirt scoops on a plethora of websites, I came across some very informative posting whereas others were rather venomous, non-informative, and written by someone who did not even know what a dirt scoop does. In reading these bashings, it became apparent to me that some of these individuals had never even used a dirt scoop. Why do people want to add their 'two-cents' when it is based on nothing??? The reason I ask this seemingly rhetorical question is that I am also a member of a Porsche forum and many of the postings one reads are presumably placed by 14-year olds that are (of course) non-Porsche owners. Then, when someone challenges them to explain/defend their position, much hatred is spewed. What is wrong with people?
In closing, I love my 30" King Kutter Dirt Scoop.
Daryl Greene
   / Dirt Scoop - the next best thing to sliced bread #2
Way to go Daryl, I have a wooden handle that goes on this after hooking up to allow me to easily dump. This in combination with my loader allowed me to dig and move well over 50 yards of dirt several hundred feet. Sure beats a wheel barrow.:thumbsup:
   / Dirt Scoop - the next best thing to sliced bread #3
I don't have a loader ...I use a dirt scoop and it works great. Good luck with yours!
   / Dirt Scoop - the next best thing to sliced bread #4
Scoops are an unrated tool. I moved a bunch of dirt from my basement excavation with one. Can also be used to smooth and level, too.
   / Dirt Scoop - the next best thing to sliced bread #5
I have one that I inherited along with the tractor when my father inlaw passed. I have not used it yet, but am going to hook it up tomorrow. I have a couple of high spots that screw up my mowing, and a couple of low spots that need filled, so I think it will just about even out. I also have a box scraper that I have only used a couple of times, but the high spots and low spots are a couple of hundred yards apart with lawn in between so I think the scoop will be getting a workout tomorrow.
   / Dirt Scoop - the next best thing to sliced bread #6
My dirt scoop was one of my first builds. I copied the KK as best I could from pictures. I have used it to move 10-12 big dump truck loads of clay, soil, and sand to back yards front yards and various places in between. Most of the work has been with the scoop in the reverse position (because I have done most of the work from piles dumped in a driveway or front yard).
When I added my quick hitch I could no longer easily reach the trip mechanism so after considering other options I made a linkage to trip the pan. It has worked very well and has been a most used implement of my meager collection.
Mike
   / Dirt Scoop - the next best thing to sliced bread #7
I have never used a dirt scoop. I do have an FEL. I have seen several scoops for sale, (on the cheap.) My question is If I have an FEL would a scoop augment the FEL sufficiently to justify it's purchase? Seems to me that if I have an FEL there is no need for the scoop.
Thanks,
Bart
   / Dirt Scoop - the next best thing to sliced bread #8
Mike
Mike
I know its mounted on a smaller tractor,but thats either aheck of a dirt scoop.
Or one bad a@@ carry-all. :thumbsup:
Boone
   / Dirt Scoop - the next best thing to sliced bread #9
Thanks,
Bart
You can use it in tanden like Winston did. It will increase your holding capacity. Say you were moving pea gravel or something for your drive, that is 1000ft long. You fill the loader up and then the scoop and you can carry almost twice as much, reducing the trips back to the pile. you can dump the scoop smooth it then the loader and smooth it or vice verso most likely. You will not have to tral inbetween as much. This is about one of the few situations where it will benefit you. Or say your digging a pond with your loader :confused2: and a scoop, you will carry more each time.
Mike,
During my research, I repeatedly examined your 'menagerie of metal'... in absolute amazement. I would be interested in seeing a close-up of your linkage that you fabricated to trip the bucket.
Daryl Greene
Non-Running Proline Walk Behind Lawn Mower (A57454)
Non-Running...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59575)
2020 INTERNATIONAL...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A60429)
(INOP) 2016...
Rotary Two-Post 10,000lbs Lift (A56860)
Rotary Two-Post...
2015 CASE 621F WHEEL LOADER (A58214)
2015 CASE 621F...
