which Stihl string trimmer
/ which Stihl string trimmer #1
buck12
Mississippi
Kubota 5460HSTC
My old Weedeater trimmer is worn out. I am in the market for a new string trimmer. I have a 1.5 acre yard which includes a shared pond. Between the pond, fence, and edging I have a fair amount of trimming. I am considering the Stihl FS55R. I bought a new Stihl chainsaw earlier this year and opted for the pro model but I don't want to ante up the extra money for a pro model trimmer unless there is a valid reason. Any thoughts?
/ which Stihl string trimmer #2
I have had a Stihl FS55 for about 5 years now and have been very satisfied with it. I trim around a 2 acre yard, including high grass along a creek and in an evaporation pond.
So far, it has started and run well every time I pulled the handle. Uses a lot of gas, but is very powerful.
two_bit_score said:
I have an FS-70, which is a low end commercial model.Love it.
Have you considered a combi?
Combi?
/ which Stihl string trimmer #5
I've used Stihl products commercially for over 15 years. I've found the newer "4-Mix" 4 stroke models to be much more reliable than the older style 2 strokes. I used the FS85 2 stroke but switched to the FS110 4 stroke. The difference was 20 but it was money well spent. The FS110 starts first pull every time and is a lot better on fuel.
I don't have any experience with the smaller units, you won't be disappointed with the FS110
/ which Stihl string trimmer #6
It's actually Kombi. I edited it. They are able to take a lot of different attachments.. Blower, pruner, Hedge trimmer, cultivator, etc.
Look in the Stihl website under multi-task tools.
I think in the long run for a homeowner they would be the best bet.
buck12 said:
I looked at Stihl's website and see it's their power head with multiple attachments. I thought about this route but the only attachment I would use is the pole saw and I borrow my Dad's pole saw for the few times I have the need.
/ which Stihl string trimmer #10
I have what must be a 20 or 25 year old Stihl FS62. It wasn't cheap when I bought it, but it's been a great value. Never had it serviced. Starts after about 5 or 6 pulls - it's always been a slow starter. Not too bad on fuel. It has sat, unused, for 2 or 3 years at a time in storage when I lived in apartments. I'd get an angle head (not the curved shaft) model if I were to replace it. If you need to cut tall, tough grasses around water, like phragmites, then you'll be wanting a blade cutter rather than a string cutter on the end and a fair displacement engine to drive it. That FS110 that Steve HEF mentioned looks like a nice one. Do yourself (and your back) a favor and get the wide handlebars and shoulder strap - then you can cut for hours and still walk the next day.
-Jim
/ which Stihl string trimmer #11
Spend the extra $30 for the FS55RC (their easy to start system) and I think you'll be glad you did. Mine is 6 years old, and it's been worked hard. My own city lot isn't much challenge for it, but I do some others in one to two foot high grass and weeds.
/ which Stihl string trimmer #12
My brother does a fair amount of trimming over 4 acres with his FS55-he has had it 5 years and has served him well. I have had a FS85 for 9 years, with no problems, trimming 4.5 acres. I think he paid $200, I paid $300. Take your pick-I'm just a sucker for commercial machines.
Will
/ which Stihl string trimmer #13
I first bought the FS70 with the easy start system. Tried it for a week, didn't like it, returned it and bought the 100. It was about $30 more, but well worth the money. Its very light, powerful and easy to start. The only thing that is lacking with the 100 is that it is a dedicated line trimmer, and cannot be used for any other implements. The 110 is the best of both worlds. It is powerful and the head can be changed to use with any of the other implements, but its a heavier unit.
I didn't like the so called "easy start" system, on the FS70. It may start in one pull rather then two, but it requires A LOT more pulling force, which I didn't like. If mine had a loop on the pull line, instead of a "T", you would be able to start it with your pinky. Its that easy to pull.
In my opinion the professional series is the way to go. My Dad bought one 27 yrs ago and is still using it today. That pretty much says it all.
/ which Stihl string trimmer #14
I'd like to try some of the others because this really surprises me since my FS55RC is so easy to pull to start. The salesman, 6 years ago, jokingly said they call it the "Granny start" because it's so easy.
/ which Stihl string trimmer #15
I bought an FS 56C-E last year. I like the bike handles for flat level land, they can be a little cumbersome when trying to trim a bank however.
This year I bought a KM130 with the pole saw and culitvator attachments for the garden. (Replaced an old Ryobi quick attach setup)
That thing is awesome other than the $925 price tag.
/ which Stihl string trimmer #16
I have the FS110R trimmer and it runs great. I also bought the Kombi 110 head and a handful of attachments. I wish I bought the Kombi first, the FS110R is redundant and one more engine to look after.
If you just want a trimmer, just get a trimmer, but if you want a KombiTool definitely get the 110, it fits every Kombi attachment available. The 130 and the smaller units are not compatible with the complete line of attachments.
two_bit_score said:
I understand. Thought that too. Kinda wish I had bought the Kombi unit to start with now. What saw did you buy?
The 260. I love it for my uses, mostly limbing and cutting fallen trees at our remote property.
/ which Stihl string trimmer #20
Woo-hoo! I didn't know that anyone was making 4-stroke trimmers. Isn't there a big weight penalty for a given power?
I've used Stihl saws since I was a kid and always got along with them just fine. But then I bought a trimmer a few years back (six, probably) FS85 sounds familiar but I'd have to go out to the barn to be sure. I've hated that miserable starting SOB since day one and I'm too old to have hardstarting issues with tools!
Only thing I've ever had that was worse starting was a MacCollough saw that I got cheap 35 years ago (and quickly knew why).
The trimmer has the little bulb primer (is that the supposed "Quick Start" system?) but it doesn't seem to help much - the only way the silly thing starts well is on raw gas, no oil. (could it use something besides 55 to one?) Anyway it doesn't want to run on my saw mix and gets me almost too tired to lift it once it's ready to go.
So news of a 4-stroke is hot stuff to me! I'll go look around the website. Thanks much for posting this, Steve.
2008 MACK CHU613 DAYCAB (INOPERABLE) (A67714)
2008 MACK CHU613...
1999 Johnson 25hp Boat Motor 225hp 2-stroke Boat Moter (A66738)
1999 Johnson 25hp...
2015 KUBOTA F3990 MOWER (A66091)
2015 KUBOTA F3990...
2017 Eager Beaver 20XPT 27ft 24 Ton T/A Tag Trailer (A66736)
2017 Eager Beaver...
2006 SUPERLINE DO20T192ALP T/A 20FT TRAILER (A66091)
2006 SUPERLINE...
CAT 963D Cab (A68134)
