Forks Clamp on forks - finally got a set...
   / Clamp on forks - finally got a set... #11
How tall are the forks, an inch, 2 inches?
I'm not close to my tractor now so I can't just step out and measure it but....
the forks are made with the same tubing that the stake pockets are made from. So, if a piece of 2x4 lumber fits just inside it, the tubing is probably a little bit less than 2 1/2" x 4 1/2" on the outside dimensions.
   / Clamp on forks - finally got a set... #13
Thanks for the measurement. I am trying to get under a hot tub but only have a 1 3/4" gap at best.
   / Clamp on forks - finally got a set... #14
If the hot tub is empty, you'll have no problems, it will raise right up(they aren't that heavy). I worked at a place where we plumbed them, then loaded by hand a took to the job site.
   / Clamp on forks - finally got a set... #15
As a matter of fact, this brings back a memory.
We delivered a hot tub to a house, the guy looks at the guy I was with and says..............I've got a 4 foot sliding door, how ya gonna fit that 8 foot hot tub in there?.......
My buddy was speechless..........had no clue what to say.
The guy then asked me(cause I was snickering)........
I said........when we rounded the corner with the pick-up,...............I noticed hinges on the wall, if it were me..............I would just swing the walls open.
He had 2 ..........11 foot walls on hinges.......a 22 foot opening for an 8 foot hot tub:laughing::laughing::laughing:
   / Clamp on forks - finally got a set... #16
Mine is sitting on a concrete slab and and needs centered up between a couple new poles that support the new roof over the tub. I drained the tub and 3 of us still couldn't get it to move. This one has jets in the center bottom coming from a sphere that must hold water. My other tub, you could at least scoot it around but not this one.
Funny thing is, I just had a guy move our lofted cabin and now the tub needs moved. Between the both of them, I could had bought the forks for what I will pay to have things moved.
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2021 FREIGHTLINER...
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
40' CONTAINER (A51244)
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
