Buying Advice (New Guy here) Which Kioti??????
/ (New Guy here) Which Kioti?????? #11
My rear tires are loaded and a 4x5 bale on the FEL can raise the rear off the ground if I don't have a counter weight on the 3 point. No way would I attempt to stack bales 3 & 4 high without the rear tires loaded. Like Jimmy said, have your dealer load them before delivery since they know what type of fluid to use that is not corrosive to the rims.
I had the plastic canopy & due to "operator error" I cracked it driving under a low hanging branch. They cost about $300, so insead of replacing plastic with plastic I made a steel one: http://www.tractorbynet.com/forums/kioti-owning-operating/172572-roll-cage-new-steel-roof.html
I must say MotorSeven you really have a nice rig. I checked out your pics and you make it look easy. When I get my rig I will have to rememer to check out all of the extras you have done to your rig. I like the metal roof over the plastic. Looks like you are the man to talk to about a DK40. Thanks again to all of you for your advise.:thumbsup:
/ (New Guy here) Which Kioti?????? #13
Hey, he is from TN, so he must be a good guy! :cool:
Yep! I am form TENNESSEE and proud of it!!!
/ (New Guy here) Which Kioti?????? #16
Add some ballast ... great advice. All bucket work is unique and will supprise you when you least expect it. Loads vary, traction varies, and stability is never constant when using near capacity loads.
I love my DK-40HST and get great service from it using the loader 90% of the time I'm on it...
Good luck on your decision.
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A61307)
Case Wheels for...
1005 (A61166)
1005 (A61166)
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
