2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,540
My trailer coupler came undone while I was backing my zero turn off the trailer and the mower nearly went vertical. Got it off the trailer, but now oil is pumping into the carb via the breather tube. The engine will run better at low speed, but give it any load, and the carb really loads up with engine oil and dies.
It's a 18.5 HP Briggs Intek OHV with a reed in the breather. Other than replacing this reed, any other ideas? I drained the carb bowl, but I could see new oil pumping into the carb throat when the engine was running when I pulled the air cleaner off.
To replace this reed, I have to pull the flywheel. Any way to do this without buying the Briggs flywheel puller?
