New L3200
/ New L3200 #1
Joe W
Southeast Wisconsin
Kubota L3200
I just bought a new L3200. This is my first tractor minus a 10HP john deer lawn tractor. Is the owner's manual serious about babying this thing for 50 hours? What can and can't do?
Thanks
Joe
/ New L3200 #2
There are several threads on break-in, interesting reading.
I have broken in three new Kubotas by following the manual and didn't baby them, just varied the RPM and no full throttle operation for a while. I worked them fairly hard bush hogging and such.
/ New L3200 #3
This is where the manual makes no sense to me. They say no full throttle operation for the first 50 hours. Well guess what my PTO speed is?........Full throttle. So I can't mow for the first 50 hours? Sometimes the grass is to thick to operate any less then full throttle.
/ New L3200 #4
I don't know where the PTO speed is on your L, but on my B, it is 400 rpm less than full, wide open. Interesting.
I personally would not run wide open. I'd run up close, but not WOT for an hour or two. I'd vary the rpm, slow down my ground speed, take half bites, etc.
No, you can't really baby it and still do hard work, but there's a few simple things to do to make your break in reasonable. I broke in a BX two years ago and the B2320 this year. I don't really give it a whole lot of thought.
/ New L3200 #5
I very rarely - if ever - mow at PTO speed (which BTW, isn't full throttle .... on my B2910)
/ New L3200 #6
Full PTO 540 speed is about 350 rpm short of full throttle on my L3400HST
but like others I often mow less than PTO 540 speed, depends on how rough the area is that I am mowing.
James K0UA
/ New L3200 #7
The PTO mark on the tach on my L4400 is at 2600 rpm. Kubota's bochure states the max HP is at 2600 rpm.The manual states PTO mark on tach indicates 540 rpm at 2650. When I'm mowing, the throttle lever when wide open, maxes out the tach needle at the PTO speed mark which is max speed. I don't always mow wide open but at times I need to.
/ New L3200
Thanks Guys! Good to know I can actually use this thing sooner than in 6 months!
/ New L3200 #9
None of my Kubotas run full throttle even after break in; guess it depends on the tractor. My 2200 didn't have a tach, so I ran it high enough to get a good cut, but not full throttle. When it was fully broken in I ran it full throttle, but don't own it now. We have a 2660, L5030 and M8540 and none of them have PTO at full throttle though the 2660 is close.
As others have mentioned, you can get a good cut, good power at less than PTO speed on most models.
We bought our M8540 in the middle of summer and immediately put it to work pulling a ten foot bush hog. I took time occasionally to let it cool down and vary RPM, but certainly did not baby it.
/ New L3200 #10
i to started working my tractor as soon as i got it.i think the highest ive ran the rpms is maybe 2200.but my main working speed is 1500 to 2000 rpms.i know a guy that always ran his tractors wide open when ever he could working them.he would also run a disc cutter as fast as he could stay on the tractor.
/ New L3200 #11
The L2800, which is the predecessor to the L3200, has the PTO mark at 2300 to 2400 rpm. That is where I run it to mow. Any other time it gets run at 2100 to 2200 rpm. Max RPM is 2800. It sounds like BigBull338 knows my dad.:laughing:
/ New L3200 #12
Thanks
Joe
Just use it and enjoy it. Babying it will do it no favors. Work it, run it and have fun.
/ New L3200 #13
When I run my tractors near max rpm, I keep feeling that I have to rush, and I find myself hurrying to get things done. perhaps to keep up with the tractor:D. When I run at more modest RPM's I find myself taking my time more, relaxing, and enjoying what I'm doing at the time. I usually break less, learn more, and do a better job. The early BX I had needed near full rpm to do anything, and that is one reason I sold it The newer ones sound smoother, and somewhat quieter to me anyway.
1992 Rammax 7430 Trench Packer and Extra Set of Drums (A62613)
1992 Rammax 7430...
NEW IDEA 323 - 1R CORN PICKER (A64277)
NEW IDEA 323 - 1R...
2011 Takeuchi TL250 Compact Track Loader Skid Steer (A64553)
2011 Takeuchi...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
1980 Fontaine Flatbed Trailer (A65563)
1980 Fontaine...
Landhonor No Till Seed Drill (A62679)
Landhonor No Till...
