Will cut Bamboo Sprout in my garden?
   / Will cut Bamboo Sprout in my garden? #1
clemsonfor
Super Member
Greenwood Co., SC
Yanmar YM2000
Ok heres my question. I have just cut a few bamboo stakes for my garden, fresh cuts on green bamboo. It occurred to me about halfway through the 10 or so i cut that this stuff might sprout, so will it? As a forester i know this stuff is horrible and will grow anywhere, but will it sprout from a cut stem just pushed into the ground. Thinking back now i should have cut these months ago and let them dry before i used them. So should i pull up the 4 or so i just put in?
   / Will cut Bamboo Sprout in my garden? #2
I don't know, but the stuff is sure awful...We have tons of it...:mad::(:confused2:
   / Will cut Bamboo Sprout in my garden? #3
I don't think it will sprout since it needs a rhizome in the ground. Mature canes won't sprout without the a rhizome.
I did not know if it could sprout from a bud in one of the little branches or not, like other plants like roses will do if you cut a shoot. I definitly dont have a rhizome.
Im not planting it either.
   / Will cut Bamboo Sprout in my garden? #6
Oh man if it's American bamboo, that stuff is so invasive, I've seen it push up 4" thick asphalt and sprout thru it. I had a shop for awhile in an industrial area near the train tracks, I got the place cheap cause it was a dump, the bamboo took over a large part of the property, I had it cut back and controlled pretty good with some type of poison. I sold the place 8 years ago and I see it's taking over the property again. the new owner was using a dozer on it!!
JB.
   / Will cut Bamboo Sprout in my garden? #7
We have a "japanese" bamboo here, terrible stuff.
local DEC doesn't even have a good solution, other
than injecting the rhizome with roundup while the plant
is flowering late summer.
if i cut or pull a bunch, it's interesting to put into
a fire pit! sounds like big popcorn as the cells
pop.
SO am i safe you think or should i pull the bamboo shoots out of the ground?
   / Will cut Bamboo Sprout in my garden? #9
Leave 'em in the ground. Without the rhizome, they are just fishin' poles.
Thanks for the advice, i was thinking i was safe but i did not want to take a chance and get this stuff established in my yard where i have none.
2 ROLLS OF CORNING OPTICAL CABLE (A50854)
2 ROLLS OF CORNING...
2014 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2014 MACK GU813...
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A51039)
2006 Magnolia Dry...
2010 International 4300 2,000 Gallon Water Truck (A49461)
2010 International...
2018 PETERBILT 579 DAY CAB (A51222)
2018 PETERBILT 579...
