Mowing Tractor vibration
/ Tractor vibration #1
dahewat
Kubota L3240DT FST
I have a Kubota L3240 FST with Land Pride 60" rotary cutter. My question is (no experience with tractors) is when I run the rpm up to PTO speed about 2550 the tractor vibrates. When I mow at around 2200-2400 I have no vibration and a nice cut. Could I have something adjusted incorrectly?
/ Tractor vibration #2
It's not uncommon for many bushhogs to cause some small amount of vibration, but the question is how "bad" is your vibration? Possibly you have a blade imbalance that generates a vibration at or above a certain rpm (frequency), or the PTO driveshaft itself can also cause a vibration. If you have a stumpjumper that the blades are attached to, that could also be bent or warped and cause a vibration. Have you tried raising the BH up and watching the blades and pan while slowly rotating them by hand? WARNING: IF you do that, MAKE SURE you have the bush hog blocked up with jackstands so there is no chance of it falling on you!
Sometimes the blades (which are made to pivot) will rotate such that when it stops they will sort of fold back on each other and get wedged together. This will cause a LOT of vibration as soon as it starts to spin up though. You will know that right away, but it doesn't sound like this is your problem.
If you know someone with a PTO shaft of the same length and ends as yours, you could swap just to try and see if that makes a difference. (If you try that, make sure their tractor doesn't have a similar vibration so that it's a valid experiment). Good luck.
/ Tractor vibration
Thanks for the reply, I will try that. I wouldn't say it is a bad vibration but is a lot less below the 2500 rpm range. Thanks again.
/ Tractor vibration #4
you probably are just turning the pto too fast. 2200 rpms should be turning about 540 on the pto. i would watch my gauges and see if the vibration is from overspeeding.
2012 VOLVO SD105DX SMOOTH DRUM ROLLER (A64279)
2012 VOLVO SD105DX...
2017 Bobcat T770 Compact Track Loader (A63689)
2017 Bobcat T770...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
2007 Freightliner Columbia 120 S/A Day Cab Truck Tractor (A61573)
2007 Freightliner...
2007 PETERBILT 379 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2007 PETERBILT 379...
2018 John Deere 470G Hydraulic Excavator (A61572)
2018 John Deere...
