John deere 2320 starting
/ John deere 2320 starting #1
critter986
Member
John Deere 345 & Kubota B3200 FEL
I was just operating a 2320 yesterday. The machine ran great however when starting, it jars the whole machine once it starts and then it stops once at idle. This isn't a very big concern however it doesn't seem like it should do this. Does anyone know why it's doing this or have the same problem?
/ John deere 2320 starting #2
I think what your describing is normal for diesels. They have a lot of compression, and torque.
Yes, but we have a slightly larger Kubota tractor and it doesn't seem to do this
/ John deere 2320 starting #4
The kubota may have better engine dampeners/suspension than the 2320.. The 2320 only has those black rubber feet where the engine mounts to the frame
Brian
/ John deere 2320 starting #5
Mine also has a brief shaking when it starts. I think it's a side effect of the engine mounts. They are probably tuned for the operating range and allow more movement at lower RPM. I'm pretty happy with the low vibration at operating speed.
/ John deere 2320 starting #6
my 2320 dose sam thing.
/ John deere 2320 starting #7
Hiya,
Nothing out of the ordinary. Should try the older Cummins B and C engines, they make trucks rock and roll when they start and stop.
It all has to do with rotating mass of the crankshaft and other rotating components. The less mass in motion will change velocity quicker when the engine is started and stopped. What your feeling is this lighter mass running up against the high compression ratio and stopping quickly, that imparts a counter reaction on the block which is what you feel.
Tom
2021 Ford Explorer SUV (A61574)
2021 Ford Explorer...
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
2022 EZ-GO ELITE...
LILLISTON 2R ROLLING CULTIVATOR (A63291)
LILLISTON 2R...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2017 Buick Encore Preferred SUV (A61574)
2017 Buick Encore...
