New L5240 Starting Rough
   / New L5240 Starting Rough #1
AJNF
Kubota Grand L5420
Hi,
I am a first time Kubota owner. I sold my JD and went orange last month and so far I am very happy. There is one issue I am concerned about and I would like some input from the members.
When I start the tractor it idles very rough and blows a lot of white smoke. I had the service tech back out to have a look at it and he said that was normal. At the same time he also noticed the coolant was low and topped it off. He said the coolant was low due to the addition of the block heater and there may have been a bubble in the system. I have owned several diesels (both tractors and trucks) and I know white smoke is never a good thing when it comes to diesels.
I took a video of the tractor starting so you can get a better idea of what I am talking about. It was about 65 degrees out and the tractor had sat all night. Here is the link YouTube - ‪New Kubota L5240 Starting Rough‬‏ or you can click here
Thanks for your help.
   / New L5240 Starting Rough #2
My manual says to start at half throttle, I have no idea what it would do starting it at such low RPM. What does your manual direct on start up? Maybe your system is different than mine as you may have the new emissions controls.
   / New L5240 Starting Rough #3
Hi,
Funny you should post this. Your video is a exact duplication of my L5740. I believe it is to do with the emissions and the EGR. As near as I can determine they all start like that with this particular emission setup. If you could find a MX5100 I bet it would not fart around like these as it does not have the EGR setup.:D
   / New L5240 Starting Rough #4
I tried to get Kubota to answer why they say half throttle at start, couldn't get
an answer. We start at idle with our L3940 and it doesn't seem to be having any
adverse affect on it yet. It started at least once a day, everyday, 365.
   / New L5240 Starting Rough #5
Because they want to sell new tractors. I start every engine at the lowest idle it will run at.
Try a half throttle start on an engine at -20 everyday and see how long it lasts:eek:
   / New L5240 Starting Rough #6
Actually quite a few manufacturers reccomend advanced throttle starting. All three of my nh skid steers up to a 305 ci stated to start at 1/3 throttle. Ill agree 1/2 seems excessive, but ill also say that with the eg,r idle starts are rough as well with inconsistant ignition and coking. Try 1/4 throttle and back off upon smoothing out.
   / New L5240 Starting Rough #7
I make it a point to set the throttle at 1500 rpm when I shut it down. I remember reading that cold starts at idle are not good as the engine is turning too slowly to pump oil to all areas of the engine before it starts.
   / New L5240 Starting Rough #8
I guess it's just me, but I figure the people who spent millions of dollars in R&D and manufacturing know more than I just because I happen to own a couple of tractors. I doubt either way will cause catastrophic failure.
From another site on cold starts:"Let it Idle"
"In cold weather, after your tractor has started, let it stand and run for a good 20 minutes. Adjust the idle up to around 1500-1700 RPM and just let it sit. The reason we do this is so that the heat of the engine dissipates into the transmission, transfer case and gear drives of the tractor. If we went to work right away, the gear oil is so thick that the hydraulics will not work and shifting gears is problematic. A common service task is to repair a shifter fork during a cold weather season the gear oil is so cold and thick that when the operator grabs the stick to put the tractor into gear, the shifter fork breaks off inside the transmission costly. Let the tractor warm up for a period of at least 20 minutes when in cold weather."
I am no expert, so take it for what it's worth; don't mean to start a debate.
   / New L5240 Starting Rough #9
I agree, everyone worries alot about the engine when the hydrostatic pumps and transmission components are the most sensitive to cold starts. I always go easy on the hst for the first 5-10 mins of use and never over 1/3 pedal for the first 50 feet or so when its below freezing. Good point of interest trip.
Thanks for all the great feedback.
I pulled out the owners manual and it indeed says, "Set the throttle lever to about 1/2 way". Seems strange to set the throttle to such high RPMs to start an engine but I will give it a try.
One would think if hi RMP's were required to start the tractor they would simply use some sort of automatic advance. But then I guess it's not a car, it's a tractor, although it did cost more than my last car ;- )
I will post a follow-up video with the throttle advanced.
Thanks again
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
RoGator RG1100C (A52128)
RoGator RG1100C...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2000 BOMAG BW172D-2 SMOOTH DRUM ROLLER (A51242)
2000 BOMAG...
John Deere HPX Gator (A50514)
John Deere HPX...
Hyster H155XL Forklift (A48837)
Hyster H155XL...
