Tire Advice
/ Tire Advice #11
Speaking from personal experience, chains on turfs make for some very agressive traction. Best to keep them off for pavement or grass, but they go on pretty easy after a little practice.
/ Tire Advice
It's 4 wheel drive. I contacted a 'Traction tire chain' company and the first thing he asked when I was ordering was, " Are your tires turf type "? He said that chains are designed for Ag tires and wouldn't fit per size if the tires were turf. He said I would have to get a dimension across the flat of the tire by using two flat boards one on each side then to get a measurement between the boards. Said he has run across this problem many times.....?
/ Tire Advice #13
Often, the R-3 size is different than the R-1 size. But there are a few sizes that overlap. I would write down the tire size and call another outfit.
/ Tire Advice
After I talked with you I called my dealer and he said that Kubota had three different sizes of rims with turf tires??? There seems to be much to be said about standardization...don't you think?
/ Tire Advice
Ordered a set of chains yesterday. That ain't easy either. Seems as though Turf tires present thier own set of dimensions. Hope they work. smoker
/ Tire Advice #16
I think you'll be happy with the added traction you'll get from installing the chains.
However, depending on the type of chains, you might not want to run them on asphalt. If they're the 2 Link or 4 Link "road" chains, there will be little marking as long as you don't make sharp turns. If you got a more aggressive style chain, I suggest you stay off the asphalt (use a couple sheets of plywood if you need to cross the driveway).
/ Tire Advice
I'm hoping these chains will fit. I had to take a couple of measurements so that the chain man could try to find the right ones. I settled for the pick-up style because I have very little clearance between the top of the tire and the fender. I can by pass the driveway with little trouble. Now I need to build/buy some weights to hang on the front. I have a loader but when we drop trees we top and limb them right there and then I push the brush out of the way so I need the bucket empty so I can work. Thanks for the response Roy. smoker
/ Tire Advice #18
You might want to reverse your wheels to increase clearance. Measure the rim to hub offset (both inside and outside) to see if there's any advantage to reversing. The clearance on my Deere 4400 increased about 3" per side when I reversed the rims. Tirechains.com recommends at least 2.5" clearance, BTW.
Also, some Kubotas have holes in the fenders to position them higher or lower (also to increase clearance). I have no idea if this would be applicable to your 9200, however...something to look into though.
/ Tire Advice
Definately will check out the reversal idea. We used to do that when I was a kid to make out cars/trucks look better :). I used a place called Traction tire and the person there was very helpful. I never thought trying to get more traction would be so difficult/expensive. I have a Polaris Ranger that has more traction/pull power than the 9200.....go figure. Thanks again Roy, smoker
/ Tire Advice
Checked out the rims and shallow side is already inside.....Sure hope these chains work.
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
2844 (A58376)
2844 (A58376)
2014 Timpte Hopper Bottom (A61307)
2014 Timpte Hopper...
2018 Ford F-350 (A55973)
2018 Ford F-350...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
