new owner of 5000, questions
/ new owner of 5000, questions
The next problem: hopefully this post hasn't sunk into oblivion.
I broke the bolt/pin that goes thru the front of the tractor casting and thru the rod end of the power steering ram. it appears that what was there was a 9/16" grade 8 bolt. when the bolt broke, the ram travels back the next time you steer right and drives the high pressure line into the crank pulley. real messy and a pain to repair.
but I did it.
about 4 operating hours later, (although with most of it of loader work) the bolt broke again. when it broke, I wasn't using the loader (brush hog actually) and actually had the loader bucket off.
can anyone give me any guidance to where the problem may lie? I'm suprised that that little ram can shear off a 9/16" grade8 bolt. especially when my neighbor's 5000 has a dinky little 1/2" pin holding it.
help!
karl
/ new owner of 5000, questions #42
Mine has been broken sometime in its past, before I bought it. The fix was to bolt a plate across the top portion of the anchor pin. The way mine was broken, the main casting where the pin goes throughabove and below the ram was broken. So far, this fix is working. I am having trouble getting the setscrews adjusted so that the slave cylinder on top of the Ram works in both directions. I tried the method of measuring the clearance on both setscrews and then trying it but there must be other problems. The fluid squirts out the top vent hole in the reservoir.
The recommendation from the ford dealer was that possibly the pressure relief valve was sticking. still seems suprising that it could shear that bold, but maybe.
Does anyone know where the pressure relief is on that machine? I'm guessing on the pump. gotta do some more looking.
Karl
/ new owner of 5000, questions #44
got the first one? if so valve is # 14.. if ya got the 2nd one.. i believe it is 17#
somehow I knew you'd be the one to come back with something. you are truely my ford/new holland minor deity. I shall make offerings of burnt UTF.
it could be that one, (the separate resevoir and pump.) I am praying that that's not it, but the one on top (numbers 17-21) as it'll be infinitely easier to get to. I'm really hoping that it's just stuck or a little rusty (I think there was some water in the system this winter, as it steered hard till it warmed up a little.) I got the tractor in nov, so didn't discover all the little problems till dead winter.
The shim in the illustration is my clue to pressure relief.
thanks
Karl
it could be that one, (the separate resevoir and pump.) I think you're right.(numbers 17-21) as it'll be infinitely easier to get to than any different one. I'm really hoping that it's just stuck or a little rusty (I think there was some water in the system this winter, as it steered hard till it warmed up a little.) I got the tractor in nov, so didn't discover all the little problems till dead winter.
thanks
Karl
/ new owner of 5000, questions #47
Thanks, but I havn't done much for ya but post 2 diagrams. the real work will be you spinning the wrench.
her's a side shot of my 4600.. same pump as the first one.. same as on my 5000.. is this what yours looks like?
nope. it's the second image you posted, with the resevoir above the pump, separate.
at least it looks like the pressure relief is easier to get to.
karl
/ new owner of 5000, questions #49
good luck on it.
soundguy
/ new owner of 5000, questions #50
I too am a new owner. I was told it was a 1976 Ford 5000, here are the numbers, can anyone tell me what they men.
5 10 1 4 c
I believe this means: 5-5000, 10-Agroculture,1- Diesel,
4-Independant 540, C-8 speed
next numbers are
C 1 5 9 4 5 0
Next numbers are
6 M 1 3
Please help. Ervin Smith
/ new owner of 5000, questions #51
Boy did I get ripped off. Its a 1966 tractor, but they said 1976. The loan papers say 1976. the Kelly front end loader says 1985. The dilivery papers which I didn't read, say different.
But I think my loan papers are the legal ones.
The product code is 6 M 1 3 meaning 1966, Dec. 13th. and there is not stamping for the time of day on the tractor. A for midnight, B for morning, and C for afternoon.
Boy they seen me coming.
/ new owner of 5000, questions #52
yep.. the '5' in themodel number is the clue.. it would be 'D' if it was a late one.
still.. it's a good machine. too bad they were not honest with you, since they should have known what they were selling. it's not like it's a secret what the numbers mean.
soundguy
/ new owner of 5000, questions #53
Soundguy wrote:
...still.. it's a good machine. too bad they were not honest with you, since they should have known what they were selling. it's not like it's a secret what the numbers mean.
Ditto, it is a nice tractor, I am sure you will be satisfied with it, after all.
You can doublecheck the year of make through the serial number.
TractorData.com Ford 5000 tractor information and serial number C159450, gives a late 1966.
/ new owner of 5000, questions #54
the date code and model ID'd it positively... even before looking at the SN...
soundguy
/ new owner of 5000, questions #55
for midnight, B for morning, and C for afternoon. Boy they seen me coming.
Someones Reply:
My reply:
No way am I going to stand for this, something will be done about it. Several suggest contacting the Attorneys
General and file fraud charges, but not untill I hear from them to see where my 1976 is.
/ new owner of 5000, questions #56
might be a bargening chip for better financing?
soundguy
bummer. although I've learned that with machines this age, care and maintenance not to mention hours is more important than age.
still a bummer though. good luck.
/ new owner of 5000, questions #58
should see the 62-64 2000 I just got.
steering box bone dry.. I've had the box apart 3x now trying to get it tight.. things worn slap out.. too much metal not touching other metal and lack of lube.. :)
soundguy
/ new owner of 5000, questions #59
Lastest news. I have proven it is a 1966 and the seller Rudoph Bros is going to make it right. we worked out a new price for the tractor, and I will be getting refund. Going to take a week or so, but we have aggreed upon a deal. So Rudolph Bros is going to make this deal right. And he has apoligized to me and my brother for the misunderstanding.
I want to thank everyone for their suggestions and comments on this issue it was a big help on solving this mistake. So I am going to keep the tractor and will have enough to get the throw out bearing fixed. Then is my baby.
Someones Reply:
My reply:
/ new owner of 5000, questions #60
good deal.
in my mind that's what I was thinking was going to be a fair amount of$.. ie.. to get the t/o bearing fixed.
good luck
soundguy
STORAGE FEES (A59906)
500BBL WHEELED...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2016 Chevrolet...
2015 VENGEANCE BUMPER PULL CAMPER (A60736)
2015 VENGEANCE...
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
