Gator CX starting
/ Gator CX starting #1
professor
Gold Member
jackson tn
Allis Chalmers 416S John Deere LX280, John Deere Z225 zero turn yanmar 1401 , Oliver 550 Special, Oliver 75 Lawn Tractor, New Holland 3930 4WD, Mitsubishi BDF2 Dozer
My Gator CX won't start. The battery is hot and when I turn the key There is a loud clicking noise and the engine doesn't turn over. I assume it is either the selenoid or starter.
How can I check to be sure which one it is? The engine is a 10 hp Kaw. Thank you for any help.
/ Gator CX starting #2
Have the battery load tested. Check to make sure all conections are clean and tight.
/ Gator CX starting #3
My Gator just started doing the same thing. Even jumping it with my truck battery the jumper cables get very hot and it still just clicks or does nothing. Has anyone got any updated advise on this. I checked fuses and some wiring yesterday and will check the ignition "key" switch wiring today. Seems to be a direct short or something draining the battery. Any advise would be welcomed here. Clayton
2019 KUBOTA SVL75-2 SKID STEER (A62129)
2019 KUBOTA...
Auger and Bit (A60352)
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
2013 CARRY-ON TRAILER 14 T/A DOG HOUSE (A60736)
2013 CARRY-ON...
2011 TRAIL-EZE  TE80HT48 HYDRAULIC TRAIL (A60736)
2011 TRAIL-EZE...
Frac Manifold S/A Trailer (A60352)
Frac Manifold S/A...
