TC24DA loosing power after 30 minutes of use...
   / TC24DA loosing power after 30 minutes of use... #31
RickB,
Why would having gas in the fuel cause it to run for a half hour and quit which was the original complaint?
Given a mix of gas and diesel in the tank, it will run fine until the engine gets up to operating temp, then run rough/stall, etc. I got soundly defeated on a road call once by not running a tractor with mixed fuel in the tank long enough to produce symptoms that the owner complained of. When I went back the next day (for free!) I figured it out.
Funny part was, the guy tried to blame his son-in-law until he called him and verified the SIL hadn't added fuel. "I should have known" the customer said " The SOB borrows the tractor all the time, but has never once put fuel in it."
   / TC24DA loosing power after 30 minutes of use... #32
I'll have to file that one away.I would have thought it would have taken less than a half hour to get to operating temperature though unless it was just sitting around idling.
   / TC24DA loosing power after 30 minutes of use... #33
"Funny part was, the guy tried to blame his son-in-law until he called him and verified the SIL hadn't added fuel. "I should have known" the customer said " The SOB borrows the tractor all the time, but has never once put fuel in it."
Now that is truly funny. I've got something to laugh about for a week now. At 110 deg. I needed that.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
2015 Freightliner Coronado 122SD T/A Day Cab Truck Tractor (A60460)
2015 Freightliner...
SCREENER (A58214)
SCREENER (A58214)
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
