TC24DA loosing power after 30 minutes of use...
   / TC24DA loosing power after 30 minutes of use...
Jim, I had to disassemble the dash and brackets under the hood to get to the fuel tank on my tractor as well and yes the fuel line was in the bottom of the tank.
UPDATE : Yesterday, after putting the tractor back together and filling with fresh diesel fuel I ran it for about 1 hour. Went up and down the road for about 30 minutes to get the tractor hot before doing some FEL work. Didn't have a great deal to do but in that hour the tractor ran flawless with no loss in RPM's!
I have 28 tons of gravel coming this week and will have a much better idea this weekend if she is fixed or not. The only conclusion I can draw is it had bad fuel or my buddy added gas or got water in the diesel fuel can when he filled it for me???
Hopefully you won't be hearing from me this week and that will mean she is running fine!!!
Thanks to everyone for your comments and suggestions.
   / TC24DA loosing power after 30 minutes of use... #22
Sounds like you are back in business! Hope you are able to move all your gravel.
   / TC24DA loosing power after 30 minutes of use... #23
I sure hope your tractor is fixed even though you didn't find a specific cause. All that taking apart of the fuels system either dislodged something or you stopped a small air leak, etc.
Good luck with all that gravel this weeked!
   / TC24DA loosing power after 30 minutes of use... #24
What cured it was draining the diesel/gasoline mix from the tank and using straight diesel fuel, as was intended.
   / TC24DA loosing power after 30 minutes of use... #25
If it wasn't gas in the fuel, then it was water. I am suprised no mentioned that possibility. Anyway the drain and refill would take care of both or either.
pure genius....where were you a few days ago??? LOL
seriously, thanks for the support guys!!!
   / TC24DA loosing power after 30 minutes of use... #27
There is a lesson to be learned here:
Never let someone else put fuel in your tractor unless it is your fuel from your can. :thumbsup:
   / TC24DA loosing power after 30 minutes of use... #28
Never let someone else put gas in your tractor unless it is your gas from your can. :thumbsup:
I will never let someone put gas in my tractor. Diesel maybe.
   / TC24DA loosing power after 30 minutes of use... #30
RickB,
Why would having gas in the fuel cause it to run for a half hour and quit which was the original complaint?
2007 Ford E350 (A55973)
2007 Ford E350...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
2008 Ford Escape XLS SUV (A59231)
2008 Ford Escape...
