My 2520 broke today...
/ My 2520 broke today...
It may have been sucking air from the get go Tom. You're right,it shouldn't move when it's running. The bucket though,that is a different story.Especially the curl. With a healthy load of gravel (at least 1000 lbs) the curl on my bucket will start to relax,but ever so slightly. By the time I get to the end of our road,(3/10 mile) and I hit the curl,it may move an inch or so. I'm sure that kind of movement is normal.
Hope you get your baby back soon.:)
Greg
Greg, he didn't give me a time frame, just said it was ordered... The curl on mine would go down also probably an inch or two with a bucket of dirt on it. I would only travel short distance 50-75 yards and for the lifting it was dropping 5-6" before they would get 6 bundles of shingles out of the bucket and if I would try more shingles it didn't want to lift it... Now when this is fixed and operating correctly I wander how much trouble I'm gonna get into!!!!!:eek: I really do like that tooth bar, I really can't compare the bucket without the teeth though because I've been having so much fun with it.....:thumbsup: I've been digging hard shell dirt out behind my garage and putting it on my quad/tractor paths for the wet spots it has been working great! I am sure I will be going into withdrawal before I get it back but at least I got my hydro fluid changed out at 33 hours!!
/ My 2520 broke today... #22
I'm new to the JD brand, but in my Kubota none of the hydraulics ever drooped or move when it was running with or without a load.
When I talked to the dealer they said there should be no bleed down while running also, the part for my tractor is supposed to be here Thursday afternoon and I am hoping to have it back Friday??? They also said from what I have told them that they think the line was bad from the factory....
Just got the tractor back, it is low on hydraulic fluid and there is a plastic Rivet missing out of the seat pan. They are going to run it back out or ups it to me. The line that broke was an all metal line that went from the left side of the engine block to under the seat. He said that it was split on the bend under the seat... They picked it up Monday afternoon and got it ba k Thursday night, dang fast service!!!
/ My 2520 broke today... #25
Glad to read you got it back.
You would have thought that after replacing a hyrdo line that they would check the hydro fluid level.
He said they did but then again he couldn't get up my driveway with his flatbed so he drove it up from down my driveway. I guess my driveway must of adjusted it a little...;)
/ My 2520 broke today... #27
Glad it all worked out. That hard-line still sounds familiar in where it split. Hopefully they send you the rivet and some hydro :). Now you can get back down to business.
Yeah it does sound familiar where it split to me also, the sight glass shows full when it is sitting but not once it is running. I won't be able to get the hydraulic fluid until Monday evening unless they drop some off today when I'm not home.... The weather does not look good this upcoming week and I do need to fit in a grass cutting though. At least we have it documented on the line here again so if it starts happening to other people they will know!
/ My 2520 broke today... #29
Hey Tom,
Glad to see you are GTG now.:thumbsup:
To correctly check, tractor has to be shut down, and all the hydraulics have to be relaxed. Fel on ground all cylinders retracted,3PT lowered. Then see what is in the glass or on the dipstick.:)
This is with my 3PT raised and then lowered.......big difference.
Greg
Hey Tom,
Greg
Mine shows full when sitting with the 3pt up but when he ran itup the driveway it was showing empty is.that normal then?? It seems that if it was empty it was low....???
/ My 2520 broke today... #31
Hey Tom,
I will only add let the tractor sit for about 10 minutes after it's shut down, and on a level surface.
So is it normal while running that the sight glass is empty?? Just seems lime there should be something in it while running.....
/ My 2520 broke today... #34
Tom,
Empty glass while running is normal.:thumbsup:
It seems weird,but when it's running the tractor is "using the fluid",so it's not going to show
a full sightglass.
Greg
/ My 2520 broke today... #35
Tom
Greg is right, this is a good lesson in basic maintenance. Some fluids must be checked while the engine is running and some are not. Always ensure the tractor is on level; side to side and front to back. It's all in the manual. Also, when shutting the engine down to check oil always wait a few minutes for the oil to flow down into the oil pan and then pull the dip stick. It's easy to over fill if you don't. It will soon become second nature (the rest of us take it for granted).
Happy Tractoring!
/ My 2520 broke today... #36
Just to confirm with the others, YES, it's absolutely 100% normal.
/ My 2520 broke today... #37
just want to add this, the loader does not have position control so if there is leakage thru the valve or the cylinders, then you WILL have settling whether running or not.
I did notice carrying dirt yesterday that the curl on the bucket would move down, wasn't a big deal and wasnt much an 1"- 1 1/2" but I was going downs steep grade and was losing dirt if I didn't keep checkin it.
2002 48ft. T/A Flatbed Trailer (A61573)
2002 48ft. T/A...
2002 Ditch Witch 1230H Walk-Behind Trencher (A61572)
2002 Ditch Witch...
2021 TAKEUCHI TB240 EXCAVATOR (A64279)
2021 TAKEUCHI...
2022 RBR Venturi 430 High-Capacity Pneumatic Applicator (A63688)
2022 RBR Venturi...
2025 Swict 72in Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
