Tractor Rollover with Pics
/ Tractor Rollover with Pics #1
TnWV
Liberty,WV - Putnam Co.
2003 Zetor 4341 w/FEL, 1970 MF 150, 2012 JD X530
Hello All, A friend rolled his granpfathers tractor this week and I thought I would post a few pics.
The tractor is a New Holland 3930 4X4. Luckily he wasn't actually on it when it rolled. He parked it on a path through the pasture with a round bale on front and back, and set the parking brake to help his grandfather with a bale that was coming apart. When he returned he found the tractor at the bottom of a deep holler on its side. They have three 3930's and one New Holland/Ford 5030, so he is very familiar with the tractors, but to his fault he failed to lower the FEL to the ground and relied on the parking brake. He'll not do that again.
Now for the fun part. I got to extract this thing with my Zetor. There wasn't any flat land to use as a good pulling spot, but we managed to find a couple of points that were less of a grade. My friend is a C130 pilot at our National Gaurd branch and was able to borrow some pretty good size and lengthy chains. I had my brush hog on for ballast and tied off the the front of my tractor and backed up to pull it. We had to pull it over on its wheels from about 60 feet away. Then I was able to manuever a little closer to the front of the tractor and make my way back up the mountain with it.
It was a tough pull, and his grandfather was very suprised that we were able to get it out with another tractor given its location. I had to use diff lock and move out of my own ruts a couple times, but all in all it wasn't too bad. No one got hurt and the tractor wasn't damaged at all, so luckily this just ends up as a reminder that no matter how familiar you are with a tractor, stuff happens so be careful at all times. The tractor sat on its side for about 5-6 hours, and only lost maybe a quart or two of engine oil. We let it sit until the next evening and topped off the fluids. It started right up and everything seemed to be good to go.
Unfortunately, I wasn't able to take a lot of pictures as I was operating my tractor, but did snap a few.
/ Tractor Rollover with Pics #2
Interesting post...
I'd be leery about towing from the loader (I would have used the draw bar) and I'm glad you did no damage to your Zetor.
/ Tractor Rollover with Pics #3
Glad everyone was OK. Sounds like it all worked out smoothly, Stay safe out there! :thumbsup:
Roy- chain isn't hooked to the loader. The tractor has a big pin on the front connected to the frame. I figured it was made to pull or push. I agree I would not use the loader to pull. With the land being kinda steep I figured it would be better to have the heaviest part if the tractor up hill to pull. I could be wrong about that though. I could have turned around and pulled from the draw bar once back on the path but wasn't that far from the barn so I just kept going in reverse.
/ Tractor Rollover with Pics #5
OK...I had assumed you rigged to the loader since you were running in reverse.
/ Tractor Rollover with Pics #6
Cool post, lots of good info for a tractor newbie like me.
I was helping load some sand into a form for steps that a contractor was doing for me. The steps come down a steep (about a 35-40 deg angle) but short (about 24" rise) hill going into my back yard. I had to approach it at an angle and knowing what I read here about high CG, I was keeping the loader down low, but every time I raised it the tractor (MF1010) tried to roll. It does have a ROPS, but it took one of the workers holding it upright with the ROPS to allow me to dump the sand. The first time I lifted it, the tractor started to teeter, and I dropped the bucket, real quick, out of fear, but that stabilized it.
The whole scenario was a good lesson to me, especially about approach angles, and the importance of the balance weight either front or back. Kinda like after the first time you take a corner too fast on a wet road on a motorcycle :shocked:. It's one lesson you do not soon forget.
Oh, and glad it was mentioned about (not) tying onto the loader, as I might have done that otherwise. I love this site.
The odd thing about this post, to me, is I trust setting my drag box and loader down, as a break, more than my break. Now I see why.
Handirifle- I agree about wet roads and motorcycles. Learned that lesson once very early in my motorcycle days. Didn't wreck but it was as close as I ever came and you can bet that if I got caught in the rain again I took my time.
/ Tractor Rollover with Pics #8
Here are some pics of a roll over I witnessed after the fact. I was visiting across the road and heard something out of the ordinary so investigated. I had to guess they were driving on uneven terrain with the loader in the up position. Inexperienced operators is my bet. Only damage I could see was a broken window on the cab. May have been more when inspecting after getting all four wheels back on the ground. As you can see in the first pic they were trying to upright the tractor with a hand winch at a bad angle. Don't know how it ultimately turned out but no one got hurt physically. It was a rental unit as I found out in conversation, tractor had less then 20 hrs. on it. I did not envy the foreman on the job I talked to!
/ Tractor Rollover with Pics #9
Here is the front of my 4341 before the loader was mounted
My friend started out using a hand winch before I got home from work and had zero luck moving it. They were figuring on getting a local guy with a small dozer but could not get ahold of him.
My tractor is identical to Barry's minus cab. The pin on the front is what I used to pull. I believe it is nearly as low as the draw bar.
Barry, do you have any idea what this was intended for? I haven't found it in my owners or service manual yet.
/ Tractor Rollover with Pics #11
I've never needed the front pin but being the Zetors are European you can get a front 3 point hitch assy to lift-push-pull.
The Zetor loader breaks out 5K lbs & I used it to lift my skidloader out of the ditch during the last snowfall of the season. I had a 7' blower on the back for ballast.
The thing weighs 4K lbs & I managed to slide off the apron & could not get itself back uphill.
/ Tractor Rollover with Pics #12
lots of good to know information. glad no one was hurt and the equipment turned out ok also
Thanks for the info Barry. Front 3PH makes since. I used my FEL a couple months ago to lift some monster rear tires off of a MF275 that were filled, to put brakes on it. Had to almost go full height to get them off the ground. They made rear very light and front tires sunk in the soft ground. Probably the heaviest thing I've lifted for sure.
/ Tractor Rollover with Pics #14
Tractors in Europe are often used to transport stuff on four wheel wagons. The front pin is used to hook up the wagons and push them. Some two wheel drive Zetors are (were) available with so called highway gear, air compressor, brake controller for wagon's air brakes, front suspension and four wheel brakes. I don't think those models were imported to the US. My neighbor has two Zetors. They still have air compressors but not the air brake hookup.
2017 Bobcat MT55 Ride Behind Track Loader Skid Steer (A66734)
2017 Bobcat MT55...
Steiger Panther 3 ST320 (A64911)
Steiger Panther 3...
2006 KENWORTH T800 TRIAXLE (INOPERABLE) (A67714)
2006 KENWORTH T800...
PORTA POTTY (A68842)
2016 FREIGHTLINER 125 DAYCAB ROAD TRACTOR (A65054)
2016 FREIGHTLINER...
2018 Bobcat MT55 Ride Behind Track Loader Skid Steer (A66734)
2018 Bobcat MT55...
