B2400 and B7800
/ B2400 and B7800 #1
2006LJRubicon
Kubota B2400 and Kubota BX23
Are these two tractors built on the same frame? Can parts be switched between the two? What about attachments, will they interchange?
Thanks for taking the time to atleast read.
/ B2400 and B7800 #2
They are loosely based on the same tractor, however the 7800 has a longer wheelbase, and sits on larger rubber. I'm sure some parts will interchange (especially some body parts), but I don't think you'd be removing alot of parts from one and putting on the other. They will certainly run alot of the same implements on the three point hitch, but I think you'd be disappointed trying to use the loader or mid-mount mower from one on the other. Perhaps you would get a better answer if you were more specific about what you are looking for.
/ B2400 and B7800
Thanks for the info
/ B2400 and B7800 #4
A B7800 is a bit more tractor than a B2400. The attachments may interchange as far as hook up but the power to run them won't be the same.
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
2002 Built Rite Trailer (A66285)
2002 Built Rite...
Coleman Go Cart, 2 Seater, Gas Engine (A65640)
Coleman Go Cart, 2...
IRanch High-End Tricycle (A64119)
IRanch High-End...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
2 Bottom Plow (A62613)
