auto a/c question
/ auto a/c question #1
deerefan
louisiana
1952 8N, 2005 JD 5103
My mother in law has a 2005 honda element and was driving home today from work and the a/c did something weird. It was blowing cold and she turned it up a bit b/c it was too cold. After a while she noticed the air was getting warmer. It had not gotten any better by the time she got home. When I hooked the gauge to the low side, it pegged out and would not take freon. The compressor would not kick on. Do auto a/c compressors go into thermal overload if they are low on freon? I am going back in the morning to try again, see if it cools off. Thoughts?
/ auto a/c question #2
Most likely there is a blockage in the system, most likely an orifice or valve.
Most R134a systems are charged through the high side.
You risk overcharging the system, essentially causing a hydro-lock and damaging very expensive components. I would pull the fuse for the compressor and take it to an AC shop to have the system evacuated and recharged to specification.
/ auto a/c question #3
There is no real thermal overload, just high and low pressure cutout switches.
If it is low on freon, the pressures should have shown that - very low. What were the readings - high side and low side? Ambient temp? It may have tripped the high pressure cutout switch, which would be why the compressor wouldn't cycle.
It is possible if you run the AC on MAX or Recirc and set the fan low that the condensor can ice up from low airflow over it. That would kill the cool air, but I wouldn't expect the pressure to spike.
It's possible something broke loose in the system and is plugging up the works. Need more info to go on. Check fuses, jumper pressure switches (only for a couple seconds!!) to verify, and make sure the electrical side is working too.
Look for a huge puddle of water under the car if it iced up.
Get some more info in the AM and report back when it cools down. Myself or others here can likely help out. There are also AC forums on the web with lots of great expertise.
Good luck!
Dave
/ auto a/c question #5
I charge an empty, evacuated system with liquid on the high side - until it stops taking it (engine off). Then I use vapor on the low side, and then turn on the car and AC to draw enough in to get it up to spec. But I have a limited stable of vehicles I do AC work on, and this may not work for all systems...
And the common AC system DIY problem: Never start by adding refrigerant. You need high/low side gages to see what is going on first. Then research the cause before attacking it.
/ auto a/c question
Good luck!
Dave
Will do. I consider myself a shadetree mechanic (minor repairs and maintenance, especially newer vehicles) so if is something major I do not have the right tools to fix it, therefore off to the mechanic it will go. I will report back tomorrow morning.
/ auto a/c question #7
High side ???? Careful there ...
Yes ac should be charged on the low side. If the ac is low on refrigerant. There's usually a pressure switch which keeps the ac compressor from kicking in to prevent damage to it.
What was the reading on the low side? Should at least be 35 PSI. There's always a chance that either your low or high side valve has worn out and isn't sealing and causing the refrigerant to leak out.
That would explain the ac blowing warm air.
I do MVAC work every now and then. Whenever I fix an ac before any refrigerant is added to the system. I always replace both those valves and the customers are told that before hand. Heck it's only $10.00 extra on the bill for those valves.
Cheaper than having the system leak down again and refilling once again.
Also once you open up the system to the environment you need a vacuum pulled on it to remove any contaminates.
This info is coming from a 609 certified MVAC Technician.
Certification number :94851CB76ADAB9020
Certification number was listed to show that I am really certified.
Chad
/ auto a/c question
It started working this am on her way to work. I told her to use it sparingly on the way home and i will check the freon again. This leads me to believe it was low and kicked out, but i can't be 100%
/ auto a/c question #9
I don't agree with that diagnosis, based on the info provided. If it was low, it would not be working now as it would still be low. My money is on an iced-up evap, until you have any further info/readings to show otherwise. The symptoms you described fit that as a cause, including the fact that it is now working fine. Tell her to not run it on Max/Recirc with the fan set real low, and that may solve the problem.
It is also possible that the Low pressure switch is bad or out of adjustment and letting the evap get too cold, leading to ice-up. They are cheap and easy to change without having to vent the entire system as there is a valve in front of them to keep the freon in.
/ auto a/c question
I am not too saavy on a/c work, my diagnosis was a guess at best. If the evap ices up, the air will blow warm or not at all?
/ auto a/c question #11
No a/c is charged thru the high side however you can preliminarily fill one using both ports but the high side has to be closed before running the system and finishing charging it!!!
A/C high side pressures are enough to explode a hand held can and at least blow the disc on a bottle and common sense should dictate this knowing the temp/pressure characteristics of gasses.
R-134a having a 32 degree evap @ 26 psi @ 70 degrees ambient for instance.
You need to have the system sucked out and weighed before you would know the state of charge its in and after that the tech will make suggestions but it sounded like it was low and freezing up to me and the fact you were not able to get any in makes me think the charging hose etc was to blame for that in some way?
/ auto a/c question #12
If it ices up the air will blow warm as the ice insulates the evap so it doesn't transfer heat out of the air very well, but air can still get by. Once it melts, back to normal. It can happen as I described and the system can still be functioning correctly, or there can be a problem that is causing it. The main problem that can cause this is the LP switch not cutting out soon enough.
If the low-side pressure in the system drops too low, the temp of the evap drops too low (below 32F) and ice starts to form on it. The LP switch is there to switch the clutch off before the pressure gets that low to prevent icing. That is what cycles the compressor clutch in normal use - especially in cooler weather. It also prevents the system from operating if there is a leak/low freon charge causing the system pressure to be too low to prevent compressor damage from running "dry".
If it continues to work fine, I would say it was just icing due to the conditions she was running it at and the temp/humidity. Don't run Max AC/Recirc with low fan settings, and that would solve that issue. Otherwise I need more info to go further on finding the cause.
/ auto a/c question #13
You can charge on the high side (liquid) A fast way to do it. Just make sure the bottle is upside down and weigh it. Then give it at least twenty minutes to equalize. I never do this on 134a but you can. Just be careful.
Honda had some problems a few years back with their compressors. I've replaced a few. And when a small dealer has them in stock you know it's an epidemic.
Oh. Forgot to say. Most liquid charges are done with blends so they go in equal amounts. Because different gasses "boil" off at different rates or temps when "gassing"
/ auto a/c question
Ok I see. Thanks for educating me. I will let her know about the fan speed and post back to any new findings.
/ auto a/c question #15
Not one car manufacturer in the world uses a blend and it matters not anyway how they go in the system long as its done right. :laughing:
Anyone who believes some of this mis-info on this thread is in deeper than they want to be so better let the pros take care of it and forget about dispensing this garbage or listening to it. :thumbsup:
/ auto a/c question #16
Car doc. Was just trying to clear up the high low side charge and talking about freon in general. The ports for 134a are different for a reason. So mistakes aren't made with different gasses. Never said any car had a blend. Do you feel better about yourself now??;-)
/ auto a/c question #17
You said it not me dear so just how stupid do you think we all are?
This is you.........
"You can charge on the high side (liquid) A fast way to do it."
"Oh. Forgot to say. Most liquid charges are done with blends"
Here is me.....
"No a/c is charged thru the high side however you can preliminarily fill one using both ports but the high side has to be closed before running the system and finishing charging it!!!"
"You need to have the system sucked out and weighed before you would know the state of charge its in and after that the tech will make suggestions but it sounded like it was low and freezing up to me and the fact you were not able to get any in makes me think the charging hose etc was to blame for that in some way?"
Looks like this is more about how you feel than me I care less how you use freon in general your success at it will reflect your knowledge of the task at hand dont quit your day job. ;)
cheers
/ auto a/c question #18
Stick to cars please. Car cobbler
/ auto a/c question
Guys, I appreciate all efforts to help. I would like to keep this thread above the belt and open as the problem is not yet solved. Please be respectful. If you need to bicker, do it thru private messages. Now, the car is on its way here and the a/c is still working. I will put my gauges on it, get a reading, and report back. I think the low pressure switch, from what I have read here, sounds like the culprit.
/ auto a/c question #20
My apologies deerefan. Hope you get it fixed. But freon is a touchy subject.
Caterpillar 416/426/428/436/438B Backhoe Service Manual (A63117)
Caterpillar...
2012 VOLVO SD105DX SMOOTH DRUM ROLLER (A64279)
2012 VOLVO SD105DX...
2015Ford Escape SUV (A61574)
2015Ford Escape...
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
UNUSED WOLVERINE RIPPER (A64281)
UNUSED WOLVERINE...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
