Ballast How many bags of cement to fill ballast box?
   / How many bags of cement to fill ballast box? #31
That's what I did......
I saw a post on here somewhere that they added some electrical conduit to the outside of the box. I really liked the idea of being able to carry some hand tool with you!! Either way would work really good and I really like the chainsaw idea!!
   / How many bags of cement to fill ballast box? #32
I might just go with the sand for now in mine??
That's what I did (a month ago). Took nine 50 lbs bags of sand but I put two 2" x 24" pipe sections at the rear corners and only filled the box about 2" down from top. The sand has since settled some so I could add more sand. Mine should be around 550 lbs of weight at present (with box weight added).
   / How many bags of cement to fill ballast box? #33
93Mustang,from what I've read from posters before in other threads,it won't add anymore weight when mixed.When it's cured, a bag will still be around 94 lbs.
Greg
Where does the weight of the water go?
   / How many bags of cement to fill ballast box? #35
Duffster, I would guess it (water) evaporates.
Greg
I can't believe that we haven't had some kind of cement / expert on here that could fill in the gaps.....:confused:
   / How many bags of cement to fill ballast box? #36
I am no expert, but I have done some reading, the water stays in there as a hydrate, that forms from the chemical reaction that occurs.
James K0UA
   / How many bags of cement to fill ballast box? #37
James K0UA
Correct. Concrete does not dry.... it cures. As James stated, it is a chemical reaction that causes the concrete to harden. If you've ever mixed a batch of concrete from a bag of Sackcrete, you'll recall that it takes a surprisingly little amount of water to reach the right consistancy. Therefore, the amount of weight added from the water is small compared to the weight of the dry concrete mix.
   / How many bags of cement to fill ballast box? #38
Bingo.
You will lose some to evaporation but very little.
   / How many bags of cement to fill ballast box? #39
Bingo.
So does an 80# bag of concrete mixed with water weigh 94# once it is dry??? You would think it would have to add some kind of extra weight to it???:confused:
   / How many bags of cement to fill ballast box? #40
A couple of things,
80# sackcrete is about 2/3 of a cubic ft per bag
You need about 1 1/4 gallons of water per bag
If you want to add concentrated weight in the box and have some room left over for chains and tools consider using Bayrite weight material, this stuff weighs about 36lbs/gallon. Available in 100 lb. sacks that are much smaller than sackkrete.
2005 Chrysler Town and Country Limited Van (A55853)
2005 Chrysler Town...
2018 Caterpillar 12M3 (A53317)
2018 Caterpillar...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
2006 KENTUCKY 53FT  MOVING TRAILER (A57880)
2006 KENTUCKY 53FT...
2007 Sterling Acterra S/A Dump Truck (A55852)
2007 Sterling...
2010 Ford F-450 16ft Box Truck (A55852)
2010 Ford F-450...
