Ballast How many bags of cement to fill ballast box?
   / How many bags of cement to fill ballast box?
I finally found the chart I was looking for. I don't believe I can get to these numbers based on my 5 bags so far. Can 5 94 lbs bags get to 900 lbs when mixed with water? I dont think that is the case as i dont think i added 400lbs of water?
________________________________________________
UNIT / SAND / CONCRETE /PORLAND CEMENT
BALLAST / 528lbs / 692lbs / 926lbs
EMPTY
BOX / 88lbs / 88lbs / 88lbs
BALLAST
W/EXT. / 176lbs / 104lbs / 308lbs
EMPTY
EXT. / 8lbs / 8lbs / 8lbs
TOTAL
WEIGHT / 800lbs / 1018lbs / 1330lbs
So, Without the BB extension, the box weighs 616lbs w/sand, 780lbs w/ concrete, and 1014lbs w/Portland cement.
   / How many bags of cement to fill ballast box? #22
EMPTY
BALLAST
EMPTY
TOTAL
Yeah I'm a little confused also!! :confused: I might just go with the sand for now in mine??
   / How many bags of cement to fill ballast box? #23
Point taken!! I have my rear tires filled and have been using for rear blade for extra ballast but that has proven not to be enough weight for me!! The rear blade is a little over 300# and I have the iMatch on there also not sure about the weight of that though, has to be close to 400# with iMatch... The rear tires were filled with around 260# each I believe... I will have to keep following the post to see what to add to the BB....
Good morning Tom,
For reference, I weighed our i-Match and it came in at 65 lbs.
   / How many bags of cement to fill ballast box? #24
93Mustang,from what I've read from posters before in other threads,it won't add anymore weight when mixed.When it's cured, a bag will still be around 94 lbs.
Greg
   / How many bags of cement to fill ballast box? #25
Im thinking I will just use the sand and duct tape for the inside. Worse case I can always slice the tape in the winter time to let let the sand out on my driveway, providing I keep it dry??? The cement might be the best though, I will have to ponder this decision some more I guess....
I used duck tape which worked ok, though I have some seepage. I do wonder if I did something wrong but can't imagine 4 bags of cement wrong. I wonder if the box is smaller now. My loader calls for 1300lbs of ballast and I was trying to get to at least hit 1000lbs but that may be difficult. Keeping my tractor on the ground and weight off the front axles when using the grapple is the main reason I got the box as my 500lb box blade was not enough. Thus to justify the cost of the box I figure I should at least double that. Sort of frustrated.
   / How many bags of cement to fill ballast box? #27
Maybe you can get some steel or a couple of beams and weld them onto the box?? If you welded ends on the beams you could fill them with concrete also??? Should get you closer to the weight you wanted.....
   / How many bags of cement to fill ballast box? #28
I just use sand w/ big rocks from my rock pile. Removable if needed and was more than heavy enough at max loader weight.
   / How many bags of cement to fill ballast box? #29
Not really a comment on quantity of cement/sand for the ballast box, but a suggestion for those who might want to add some extra functionality to the box. My brother and I (upon suggestions from a similar thread here several years ago) each tried this with our ballast box... We went ahead and cut several lengths of PVC piping ( I'm thinking it's 2 or 3" dia., and the same length as the depth of your ballast box, maybe a little longer) then installed them vertically in the box before pouring the concrete - a few strips of duct tape around the bottom to help secure the pipe, and keep the concrete out helps. Just just pour and adjust the PVC pipes to make sure they're perpendicular to the bottom of the box before it all sets up. Its great for carrying rakes, shovels and other items you might need to haul around the yard. I wasn't thinking that far ahead when I did mine, but you could probably even make a slot for your chainsaw ( use one of the plastic blade guards instead of the PVC pipe ). Cheers!
   / How many bags of cement to fill ballast box? #30
That's what I did......
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
2026 Hillcrest Dump Trailer (A56858)
2026 Hillcrest...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2013 Chevrolet...
2023 Kubota Z252KH-54 Zero Turn Mower (A55315)
2023 Kubota...
2003 Big Tex 10PI...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
