sunshade or not
/ sunshade or not #21
No, the ROPs are about an inch too tall to make it in my garage door when they are fully up. I may take a look at the umbrella in thatguy's post the next time I am in TSC.
/ sunshade or not #22
When I bought my first Kubota tractor (L3710) 10 years ago in Northern Wisconsin, I thought about buying a sunshade but never did. I worked with that tractor for 5 years in that area of the country without any real problems, and was probably better off without one as I did some work in the woods and around lots of trees.
This year I bought my second Kubota (L3700SU) and I live down south now in North Carolina. I bought a Kubota sunshade when I got the tractor and I would not want to be without one living here! I can go outside in any weather and get some work done without worrying about over exposure to the sun. Without the sunshade I would not be able to work very long in the summer sun and heat. Also, I don't work around any trees now so I have no worries about hitting or damaging the sunshade (I might be worried about this if I had lots of trees). I never fold down the ROPS, so I don't have to worry about that.
So, I would say think about where you are located or working with your tractor and this will help you decide if a sunshade would be just nice to have or a lifesaver to keep you going during the summer sun and heat. :thumbsup:
/ sunshade or not #23
Well, I've posted this so many times, I must sound like a broken record. But, yes, some kind of protection from the sun was a necessity for me in the Texas heat. The neighbor's old Oliver that I used so much for cutting and baling hay had one of the umbrellas and that was sure better than nothing. But when I bought my Kubota B2710, the dealer said the Wells Ag Company canopies were both stronger and cheaper than the Kubota canopies. I had a choice of diamond plate aluminum or steel painted to match the tractor. As you can see, I picked the steel and was well satisfied. There may be others as good, but I've never seen any better.
Way back in 1999, it cost me $295, but 12 years later, I have no idea what they cost now. And Wells Ag Company was located just a few miles north of my Kubota dealer so I don't think there was any shipping charge to the dealer.
/ sunshade or not
Hey, that looks pretty nice... Something I'd be interested in looking at at least.
/ sunshade or not #26
Incidentally, that steel frame and insulation allowed me to mount a work light to the front to beam past where the headlights were aimed and a floodlight to the rear, as well as a rear view mirror. I later replaced the round rear view mirror a larger rectangular one.
I also had two tiltmeters mounted on it; one for side to side and one for front to rear.
/ sunshade or not #27
Bird
Nice looking set-up, and looks very functional. I really like the lights.
Charlie
/ sunshade or not #28
Bird
Charlie
Forgot to mention, I mounted a 3-way toggle switch up on the right side; middle position was off, flip it to the front for the front light or to the rear for the rear light.
/ sunshade or not #29
I was thinking that looks familiar, I've got the mirror and the front light, no rear light though. I have factory rear lights on the rops, but they only work when the headlights are on. Most of the time when I want rear lighting I don't want front lights on.
I should just get another rear facing light on the canopy.
BTW I fished the flood beam light out of a dumpster, it casts the most beautiful wide bright beam, way better than the factory head lights, and being mounted up high on the canopy, shines well over the snow plow.
JB
/ sunshade or not #30
Bird your garage is to clean
/ sunshade or not #31
I cut the rops down 3" to get in the garage.. (here come the ROPS police).
installed the sunshade sungaurd. then added some forward stiffners because I trailer the tractor and tehn mounted lights...pretty permanant now, Have smacked on some large low branches no cracks.
Good quality for the $$$:thumbsup:
/ sunshade or not #33
I have been thinking about building a canopy for some time now, always seems like I put it off until after I needed it. :) Anyway got a call the other day to do some bush hogging for someone, about a five hour job. The temps were pushing 100 so I decided to throw this together the night before at work and see how I liked having a canopy before spending a bunch of time and end up not liking on on the tractor. The main part of the framework will be able to but used on a permanent canopy when I build one, but I took a 4 foot X 5 Foot long piece of paneling and bolted to the framework and then hung a 12 volt fan, worked great.
/ sunshade or not #34
Nice setup, Bird. I have this one in the aluminum, mounted a fan in the right front corner for A/C. :laughing:
The aluminum will bend so I am a bit of a bobble-head when working under/around trees, trying to keep it out of trouble.
Don
/ sunshade or not #36
We put this canopy off of a neighbor's Case and it works great. Two grown men can sit on the front, very strong.
/ sunshade or not #37
Let us know what sunshade you get and if you like it ,I too was thinking of one and also own a b 2920
/ sunshade or not #38
I stepped my rops back so the tube is partially open, then I just use a beach umbrella a couple Velcro straps keep it from bouncing around and when in the woods I just crank her closed. Umbrella cost me $15 it's a cheapy but it has lasted me 5 years. I only use it in the summer. I'm inspired by all the homemade canopies and may get around to making one. Though when I post a picture of it I'm moving the tractor outside
/ sunshade or not #39
In the process of buying my bx2360, I wanted to get the Kubota sunshade and just throw it on the financing. My wife, who played Devil's Advocate through the whole process, put her foot down and wouldn't go for it (I know it sounds crazy for a few extra bucks a payment but we went from looking at $1800 Sears mowers to 14K Kubotas and she had to draw the line somewhere). Anyways, for yard mowing, the first thing I noticed was how careful I needed to be with the ROPS around some of our smaller trees with low branches. At first I thought, turns out not getting the sunshade was a good idea, it'd just get in the way. Now that I think about it though, the sunshade might actually make it easier to maneuver around those branches - instead of constantly cranking my head around to see if the ROPS will clear, having the sunshade in your field of vision might let you know right away of any potential collisions. Just wondering if anyone with a sunshade sees it that way?
/ sunshade or not #40
Yep, you do have to watch where you're going whether you have a canopy or not. You can see the right rear of my canopy where I backed under a really big tree limb that wasn't as high as I thought it was. And the canopy was so strong I wasn't able to straighten that little wave.:eek:
2025 Hydraulic Brush Cutter Mini Skid Steer Attachment (A61567)
2025 Hydraulic...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
2014 VOLVO A40G WATER TRUCK (A62129)
2014 VOLVO A40G...
2025 Pabreak 84in. Hydraulic Rotary Tiller Skid Steer Attachment (A61567)
2025 Pabreak 84in...
UNUSED KJ 42'X30' METAL STORAGE SHED (A62131)
UNUSED KJ 42'X30'...
