Ballast How many bags of cement to fill ballast box?
   / How many bags of cement to fill ballast box? #11
I'm just using sifted sand in mine. I originally poured in three 70# bags and four 50# bags, which surprisingly filled it to where another full bag wouldn't fit without adding extensions. I thought it would hold more too. But a few rains and a bit of driving around settled the sand to where I can now top it up with maybe two more bags. Unfortunately you can't do that with concrete mix.
I decided I have no need for the John Deere extensions now, so they're for sale if anybody's interested. As new, never installed.
//greg//
   / How many bags of cement to fill ballast box? #12
Well,looks like the 1200 lb HF dolly is having a melt-down...We had one do that too while carrying an electric motor?
   / How many bags of cement to fill ballast box? #13
I have the JD ballast box w/ no extension and mine took 7 bags of 80lb quikrete. I added 2 - 2" schedule 40 pieces of PVC pipe one on each side. I used my hand tamper to tamp down each mixed bag I added to the box filling it to the bottom of the lip.
   / How many bags of cement to fill ballast box? #14
I'd roll the puppy into Harbor Frieght with the ballast box on it and be like what gives.
I just filled my new JD ballast box (no extension) this weekend....6 80lb bags quikcrete, 1 40 lb bag quikcrete.....
Oh......and don't buy the 1200 lb dolly from Northern tool to store it on......:laughing:
   / How many bags of cement to fill ballast box? #15
I am not sure what I want to put in my BB for my 2520?? I thought about just getting 50# bags of play sand that I would leave in the bags that way I could use it in the kids sand box when needed also... I just hate to fill it with concrete which would make it hard to carry tools and chains if I wanted to... I guess I probably wouldn't have it on anyway if I had the chains for pulling trees.. Is that the standard using concrete?? Is that what you are supposed to use in them??
   / How many bags of cement to fill ballast box? #16
I had mixed emotions about filling it with concrete too.......but the sole reason I bought it in the 1st place was.....ballast.
   / How many bags of cement to fill ballast box? #17
Point taken!! I have my rear tires filled and have been using for rear blade for extra ballast but that has proven not to be enough weight for me!! The rear blade is a little over 300# and I have the iMatch on there also not sure about the weight of that though, has to be close to 400# with iMatch... The rear tires were filled with around 260# each I believe... I will have to keep following the post to see what to add to the BB....
   / How many bags of cement to fill ballast box? #18
How did you plug the holes on the bottom of the ballast box prior to adding the cement or sand?
   / How many bags of cement to fill ballast box? #19
....... Is that the standard using concrete?? Is that what you are supposed to use in them??
Owners manual specifies filling the box with either sand or concrete.
   / How many bags of cement to fill ballast box? #20
I lined mine with duct tape but it still leaked some. I also drilled weep holes under the PVC.
2017 FREIGHTLINER M2 106 (A55745)
2017 FREIGHTLINER...
2017 Ford Escape SUV (A55853)
2017 Ford Escape...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
White Metal Roof Panels (A55758)
White Metal Roof...
2014 Ford F350 (A55973)
2014 Ford F350...
2014 Nissan Rogue Select SUV (A55853)
2014 Nissan Rogue...
