MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,641
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
A HEAVY 7 footer is a bit much for a 3200/3800 for anything other than light grading or snow. I know because I have a 700lb 7 footer for my 3400. It is about the MAX. A 6 footer WILL cover the wheel track when fully angled, because they dont angle to 45 degrees. At least most dont. They are more like 30 degrees. And a 72" blade @ 30 degrees will cover ~62".
And even a 6 foot blade on full angle with a good bite will pull a 3200/3800 sideways.
There is a lot to learn about technique when using a RB. Like steering with the brakes, etc.
I am surprised to hear that your blade does not go to 45 degrees. I have a hydraulic and a manual rear blade and a manual landscape rake and they all go to 45 degrees. Is your blade an older blade? Maybe the older blades didn't go over to 45 degrees. I'll have to check the 6 footer that my brother has, it is very old, now I'm curious if his goes over to a 45.
I have a question for you though. Would you prefer a lighter weight blade than the 700lb one that you have?
