Steering cylinder rod replace help, TC33D
/ Steering cylinder rod replace help, TC33D #1
Ltowne1
New Holland TC33D
I have removed left steering cylinder on TC33D w/Super Steer and purchased a new steering rod (old One was visibly bent and leaking) and seal kit. I have end open with spanner wrench but can only pull old rod and piston half way out. Is there a trick to removing the old rod or is this an indication my cylinder is also bent so the piston gets stuck?
Figured it out, piston was flat on one side, got out with a rod and rubber mallet, but looks to me like the tube is damaged internally so need the whole assembly now... Great...
/ Steering cylinder rod replace help, TC33D #3
Welcome to TBN.
Sorry I'm not that familiar with the parts you are having an issue with. Hopefully someone else will post with more knowledge about the hydraulic steering than I have.
/ Steering cylinder rod replace help, TC33D #5
Howd you get the left steering cylinder off the tractor? I tried disconnecting from the left front wheel, but I couldn’t pull the cylinder down enough to get it off of the bolt. It must be attached somewhere up in the frame. How did you get that off?
/ Steering cylinder rod replace help, TC33D #6
The attached is for the next size larger frame (35, 40, 45) New Holland but maybe it will give you some insight if they are similar?
  • Steering TC35DA.pdf
2015 FREIGHTLINER CASCADIA 125 6X4 T/A GLIDER SLEEPER TRUCK TRACTOR (A59911)
2015 FREIGHTLINER...
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
2014 TAKEUCHI TB228 EXCAVATOR (A64279)
2014 TAKEUCHI...
2017 Buick Encore Preferred SUV (A61574)
2017 Buick Encore...
2019 TAKEUCHI TL12V2 SKID STEER (A64279)
2019 TAKEUCHI...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
