MaxBrake Review
/ MaxBrake Review #1
Charlesaf3
Richmond VA & Irvington VA
Kubota B3030, Kubota M59 TLB
So based on the recs here, (primarily DiamondPilot) I bought a Max Brake tow controller for my 2007 Toyota Tundra. Thought I'd write a quick review for the curious.
I'm not all that qualified to do so - only ever towed things without brakes before.
But the impression I got is that it really is all that. Once installed, with trailer hooked up, I just drove like I normally do. Totally seamless, totally easy, just set the gain for the weight.
It was like I wasn't even pulling a trailer (and I'd guess I have 10k pounds back there, or close to it). Dry, the truck actually stopped faster - all the extra brakes I guess.
Basically, it seems to be simply amazing as a brake controller. Based on a completely painless 800 mile tow, including hills (Poconos) its just perfect - it does what it does without me having to pay any attention to it.
Tundra hauled 10k easily btw. Around 9.5 mpg. Plenty of juice to accelerate up the hills, no braking issues (though trailer brakes were braking it of course)
Installation was pretty painless, though I had a mechanic help. Attaching to the brake lines and bleeding them took very little time. Fishing the ethernet cable through the firewall took a while, but that's a Toyota issue, not a maxbrake one. Hint, cut the nipple on both sides...
Mounted it right above the parking brake more or less. I'm very tall, and it doesn't get in my way there.
All in, yet another reason I love TBN. Never would have heard about it otherwise. (btw, bought from Southwest Wheel with TBN discount, no complaints on that subject either). Called customer support for Maxbrake and found them very helpful.
/ MaxBrake Review #2
Glad you are happy with the Max Brake. The few I have installed now are happy customers also. I have not had the opportunity to use one yet but am sure it works just as good as the Ford Factory Brake Controller its modeled after.
By the way, I just did a 900 mile trip with my Titan from Northestern Indiana to about 1 hour south of Knoxville TN and got the same MPG as you did. It was right at 9.3/9.4 pulling a little over 9,000#.
Chris
/ MaxBrake Review #3
So I guess I just don't understand the point of this device.
With the Tundra, there's at least one plug and play controller (like the Prodigy that I have in mine) that takes 20 minutes to install, doesn't require a level mount and with the press of a button will be set for a given load range.
I tow 7-8K lbs in an enclosed trailer with my Tundra and have never had a problem and don't even really think about the controller. The brake signal to the trailer is proportionate and will only give me a bit of a lock-up on gravel roads when coming to a stop.
I read the marketing literature and I suppose I'm not following why I'd need or want this type of device.
/ MaxBrake Review #4
The advantage to the Max Brake is its pressure driven via a sensor in the brake line. It needs no adjustment and will give you more braking if you push the brake pedal harder, less if you push it less. It also gives the trailer anti-lock brakes, well sorta. It will pulsate them but not monitor lockup.
I saw a independent video where a guy took a F-350 diesel dually that had a Prodigy P3 in it. He had a 18,000# or so trailer behind it and did measured stops form 30, 40, and 60mph or something like that. He then installed the Max Brake and did the same test and beat his stopping distance substantially, something like 30%. From the guys I have installed them for and what I have noticed on my F-350 with the Ford Factory Brake Controller in it is its so smooth in stop and go traffic. Conventional brake controllers seem to get GRABBY in these instances.
If you do some deep research most brake controllers have a braking schedule programed into them. I am making the numbers up but its something like this. Initially it will give you about 75% of the power you have dialed in via the gain. It will then increase slightly then taper off to about 20%. This is over a set time period of maybe 5 seconds or so. It will then hold about 20% until the brakes are released then start over with brake application. The Max Brake and others like it that are pressure driven simply work how hard you press the brake pedal.
As for installing, its not hard at all. Maybe 30 minutes. Its plug and play in the truck just as the P3 and others. Under the hood you must route a wiring harness, the toughest part of the whole deal. You must also loosen a brake line from the master cylinder, install a "T" fitting, and thats it. No need to bleed the brakes because its the highest point of the system.
I have put in a few. Installing the controller in the truck, 5 minutes. Running the wire thought the firewall, 10-20 minutes. Installing the pressure sensor and "T" fitting maybe 3 minutes. Very simple for a controller that is hands down better than anything else on the aftermarket.
As for your controller you are running now it a good unit. I have the same one in my F-250. I have a Reese in my Titan and its about the same. I have the Ford Factory Unit in my F-350 that the Max Brake is modeled after and its so much better. Yes, the one in my F-250 and Titan are good enough but if money was no object I would have Max Brakes in them also. I don't tow really heavy with them like I do with the F-350
Chris
/ MaxBrake Review #5
Thanks DP.
Perhaps as one approaches the limits of a given towing platform, this system might have some advantages. For me, with the Tundra, the Prodigy required no splicing and no tapping, just one kick board trim R&R and then plugging the pigtail in to the factory plug on the Toyota harness.
I must admit that tapping in to the braking system aft of the master is a bit of a deal braker for me.
Tow safely everyone.
/ MaxBrake Review #6
Thanks DP.
I agree. I have a P3 and its ok, same as my Reese. Once you used anything other you would never go back.
I hear this over and over but its a direct fit vehicle specific fitting that goes in line with a brake circuit. I would guess there are 10 to 20 fittings between the master cylinder and the brakes on your truck. They are just fine so why would adding one more be of concern?
Chris
/ MaxBrake Review #7
Chris
I'd be concerned for three reasons...
1. Improper installation or failure of parts resulting in brake system malfunction.
2. Toyota warranty on brake system components (if it was still in effect).
3. The big one... Liability. I don't want to give lawyers anything they can sink their teeth into if there happens to be an accident.
The plug and play type don't interface with my mechanical brake system and are effectively factory sanctioned.
$0.02
/ MaxBrake Review #8
I agree with Ace10, completely. Anytime that you add an aftermarket device to a hydraulic brake system, that is a deal breaker for me. If the Factory puts a part into the system, it's been tested and approved.
/ MaxBrake Review #9
You guys worry too much. Do you change your oil? You are taking on and off a oil filter. I guarantee you the ratio to oil filter failures to brake fitting failures is 10 to 1.
Any vehicle made in the last 25 years or so has dual reservoir master cylinders. You have a circuit to the rear brakes and a circuit to the front brakes. Even if it blew the fitting which will never happen if installed correctly you will still have 1/2 your brakes along with the capability to manually apply the trailers brakes via the slide bar on the Max Brake unit just like any other brake controller.
Like I said before you have a dozen connections or more in a typical brake system. Adding one more is not a concern to me at all.
Chris
/ MaxBrake Review #10
Chris,
You're talking about a company that has marketed this product since 2008 (copyright)according to the site. Not at all a time proven product. When it comes to brakes, particularly with many thousands of pounds behind me,yes I do worry. I'll take the time proven design every time.
If you're not concerned to be a "product tester" with your brakes, by all means go to it!
/ MaxBrake Review #11
The Ford built in one just uses a similar sensor to the abs system braking pressure sensor. They really do work nice, everyone I've talked to who had used one wouldn't go back.
/ MaxBrake Review #12
Before we are were blessed with electronics, trailer brake controls where hydraulically activated by the master cylinder. The brass T fitting was installed and a steel brake line was routed to the brake control. A small cylinder moved the control handle mechanically.
This 'max-??' control is the best of both technologies. Next time I need one, that will be my choice.
PS: don't go crazy from the heat. Pray for our weather ravaged countrymen.
Mike....
/ MaxBrake Review #13
Pre-set, pendulum (inertia) and surge brake controls are WAY more dangerous than a pressure based brake system like Max-Brake (Ford TBC) and other previous ilks.
Why? Those systems that do not rely on towing vehicle brake pressure are almost NEVER providing the "required" braking on the trailer - either too much or too little, never the right amount.
On a damp road the trailer brakes skid causing loss of control. On a dry road, they don't produce the required braking, especially under hard brake events. This causes the trailer to push the tow vehicle and is VERY dangerous.
With a brake pressure based system, the trailer brakes are set once so the controller knows how many amps the trailer needs based on the pressure applied in the tow vehicle system. As the pressure increases or decreases so does the trailer brake force. If you very gently apply the brakes (as in wet or snow) to retain control, you get very gentle trailer braking, exactly what you need.
In a surge system, if you are on ice or snow you get ZERO trailer braking! The trailer shoves you right thru the intersection. Such systems should be outlawed!
/ MaxBrake Review #14
I agree with the latter about surge brakes. I was driving a uhaul truck with car trailer and caddy on trailer. I was approaching the stop sign from off ramp in texas where it snowed first time in long time. long story short, surge brakes never kicked in, ABS on truck was kicking in making me go farther then I wanted and I was unable to skid to stop. There are times where skidding DOES stop faster then abs does. I rolled a little past stop sign, no one was around thanks to my lucky stars. FYI I was going slow, 5-10 mph.
/ MaxBrake Review #15
... long story short, surge brakes never kicked in, ABS on truck was kicking in making me go farther then I wanted and I was unable to skid to stop. There are times where skidding DOES stop faster then abs does. I rolled a little past stop sign, no one was around thanks to my lucky stars. FYI I was going slow, 5-10 mph.
It is a proven fact, lots of testing and validation published on this, ABS actually INCREASES STOPPING DISTANCES in every situation EXCEPT "glaze ice". Yup, no lie either, it's researched to death and a fact. The "real" benefit of ABS is to retain control of the vehicle (steering specifically) and not decreased stopping distances.
/ MaxBrake Review #16
I looked at the MaxBrake instructions and saw nothing alarming about the product's installation. It's nothing more than a simple tee to the pressure sensor. Now if cutting of brake lines were involved I'd get concerned.
To me this is less involved than changing brake pads/shoes, and making sure everything is adjusted properly, especially for drum brakes.
/ MaxBrake Review #17
You should contact the AAA Institute for Traffic Safety as well as NHSTA with the information about these "tests" that have "been researched to death". I'm sure that they would want to hear that their published information is incorrect.
AAA Foundation for Traffic Safety - Resources
/ MaxBrake Review
Followup - still very hay with max brake. I understand the concern that people have with tying into the brake lines, I share it, so I had a mechanic do it. Honestly, while anything can go wrong, it's really tough to see why this would be any more failure prone than any other hydraulic fitting, after looking at it. And catastrophic failure seems the least likely case
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2018 Ford Explorer AWD SUV (A61574)
2018 Ford Explorer...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
John Deere 5525 (A60462)
John Deere 5525...
Roll of Plastic Hose (A64119)
Roll of Plastic...
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
