Buying Advice MMM size
/ MMM size #1
Hotrocks
Member
BX2200HST
Hello,
My first post on TBN. Please forgive any ingnorance I may portray as I am somewhat new to tractor ownership.
I bought a used BX2200 a couple years ago with a 60"MMM and a 42"brushhog, 275 hours, for $7,200.00. I now want to sell it and buy a B2920 HST with FEL, 5ft brushhog, and MMM. The wife and I just bought a home and 66 acres. About 15 acres of fields and rest is wooded.
With the new B2920, I'll have about 10 acres of field to brushhog and 2 or 3 acres to finish mow, and the property is pretty hilly so I want the 4x4 tractor and not a typical riding mower. I have 2 main questions:
1. I need your opinion on whether to get 60" or 54" MMM. My current 60" seems a little wide at times and was wondering if the shorter MMM would get into the dips in the lawn better?
2. Dealer quoted me $16,540.00 for B2920HST FEL and an additional $2,500.00 for 60"MMM. Is that a reasonable quote?
I apologize for the long post. I have learned a lot over the past couple weeks just reading the posts on this forum. One more thing, the B2920 as described above is at the top of my budget, so a bigger tractor is out of the question.:(
/ MMM size #2
Hello,
My $0.02 is 1) the 60" is as good as a 54" on that terrain. I don't think you'll see any finese finish with the 54 over the 60. I suppose I may be partial in that I have a 60 on a B7800 and it works very well for my similar needs.
2) A little high but value is what someone is willing to pay. I'd be happier at $15.5K - $16K. I think I paid ~$1,800 for a 60" MM in 2006. I'd say reasonable but it looks to me for a little room in improvement for a deal.
I paid $18K out the door for a 2006 B7800 (30 HP), a MMM, and a FEL. One thing about these machines, they do not get cheaper by waiting.
/ MMM size #3
When deck is as wide as rear tires you bang up deck less and don't have to look over shoulder.
/ MMM size #4
I like the 60" better because that allows an extra 3" on each side to get up under overhanging brush better. The distance across the rear wheels is about 49", so the 60" is extending about 5.5" beyond the wheels for trimming along edges.
The 5' brush hog is a stretch for the B2920. I use a 5' Bush Hog brand Squeeler. The 2920 handles it ok if I don't get too behind on the mowing, but it is a lot of weight back there and can bog the tractor down it I have gotten too behind in the mowing. If you can find a 54", it may be a better match.
I know you said the B2920 is the max for your budget. I like mine, but if I lived full time at our 12 acre property instead of having to trailer it, I would probably opt for something like one of the small L's and skip the MMM.
/ MMM size
Thank you! I was wondering if the 5 ft brushhog was to big or not...the dealer said 5 ft would be fine. But I may look for a little smaller one. And, good points regarding the 60" mower...I hadn't thought about it that way.
/ MMM size #6
I agree the price is just OK. One way to save money would be to consider the B2620. Identical tractor with just a few less ponies. Unless you honestly feel you need those additional PTO horsepower. The light weight of the 20 series makes horsepower to traction touchy. You'd never likely miss the extra power, as owners here will tell you. The exception is the PTO power of the 29 horse model. If you need it, you need it.
You might want to get a quote, through email, from Barlow's Equipment. This quote will tell you whether your dealer is in the ballpark on the price. Congratulations on your adventure!!!!
/ MMM size
Thank you for the opinions, advice, and tractor experiences. I appreciate it and will take everything posted into consideration.
/ MMM size #8
I have had 54" and 60" decks; much prefer 60".
/ MMM size #9
If you decided to consider the 2620, it would probably be best matched to a 48" brush hog. That extra 3 HP difference would equate to about a 6" reduction in recommended rotary mower size. It shouldn't make much difference with the finish mower, assuming you are keeping the grass you mow with it reasonably managed for height.
If you have a limited number of obstacles to mow around or avoid, it is worth thinking about a RFM vs the MMM. It is cheaper and certainly easier to remove or install. The MMM is easier though to get around and close to things. If you removed and installed yours on the BX, it is the same process although you do have more room to get under the tractor and hook up the PTO. The drive over deck is a little easier too, but still requires at least a little tugging to get it lined up.
/ MMM size
Thank you. That MM PTO does give me fits somedays. I was hoping the B would give me a little extra clearance to hook and unhook. And per the suggestion, if I got the B2620, I would get the 48" brush hog.
/ MMM size #11
I bought mine in April of '10, but the tractor /loader was $15,300, and I paid another $2350 for the 60" MMM. These prices do seem to vary a little regionally, but it still seems your dealer might be on the high side.
2017 FORD F-150 FOOD TRANSPORT TRUCK (A63569)
2017 FORD F-150...
2022 John Deere Z930R Zero Turn (A63116)
2022 John Deere...
H&H 100 GALLON ALLY WAY SPRAYER (A63291)
H&H 100 GALLON...
2022 Kubota MX5400HST (A64047)
2022 Kubota...
2015 Ford F-350 Auto Crane Service Truck (A61573)
2015 Ford F-350...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
