3-Point Hitch 4110 3-PT HITCH WON'T DROP???
   / 4110 3-PT HITCH WON'T DROP??? #1
RGC426
JOHN DEERE 4110
Good Morning All,
My JD 4110 3 pt hitch won't drop, I checked the flow control and it is opened all the way and they won't drop. I have not used the 3 pt since last fall when I raked my driveway. I did put the rake on hoping the weight would help lower it but nothing. So then I thought I would loosen the 2 bolts holding the flow control to the case and relieve the presure to lower the 3 pt and it did lower. I then tightened the 2 bolts back up to the flow control. I started the the tractor and raise the 3-pt back up and it would not lower again. Any suggestions??? Is my flow control valve bad? Any help would be appreciated.
   / 4110 3-PT HITCH WON'T DROP??? #2
check your draft control lever
   / 4110 3-PT HITCH WON'T DROP??? #4
Good Morning All,
It is not entirely uncommon for a small piece of debris to foul the ROD (rate of drop) valve. You may have to take it out and clean it.
I pulled the flow control out and disassembled and didn't see anything (debrie) or broken or scored parts...any ideas. Hate to buy a new valve if it isn't the problem ($800. valve)
2015 BMW 328i Sedan (A55853)
2015 BMW 328i...
2015 Audi A4 Sedan (A56859)
2015 Audi A4 Sedan...
2016 Ford Taurus Sedan (A55853)
2016 Ford Taurus...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
202482 (A54757)
202482 (A54757)
Adams 6Ton Hydraulic Lime Spreader (A55315)
Adams 6Ton...
