changing brush cutter out for 6 blade grass cutter
   / changing brush cutter out for 6 blade grass cutter #11
i didn't get any directions with this on how to mount it, other than the blades were bolted inwards for shipping. when i started to put this together i thought that it would have made sense to bolt it directly to the bottom where the brush cutter blades were attached to. but as you can see in my 1st photo, the bolt holes align at the top which hold the shaft to the brush cutter deck and not to where the blades are at the bottom. i figured that PT has some other design in mind because what they put together doesn't always make sense to us. Now that i saw red zebra's picture of how it's supposed to be i see that PT messed up with the bolt hole alignment.
jj i think i paid $350 for it.
thanks everyone for the responses and the pic on how it is supposed to be.
From the pictures of the one that is mounted, and comparing that to yours, it look like they forgot to drill the 4 bolt hoes that would attach it to the hub where the original brush blades were removed. :confused:
I talked with terry and sent him the same pictures. he called me back and said this disc wont work. i asked him if i should drill out where the 4 bolt holes would be. he said that may not work either. he's going to work on this for tuesday and get back to me. I think he may end up sending me the correct disc but he didn't specifically say that for sure. i'll let you all know the outcome hopefully tuesday. thanks again
well, i talked with terry and he said they no longer make the disc for the 1430. so, they will refund my money when i get it boxed up and they issue a call ticket for it to be picked up.
   / changing brush cutter out for 6 blade grass cutter #14
:mur:
Bummer. Well, at least we now know.
   / changing brush cutter out for 6 blade grass cutter #15
If you like the cutter, why not just drill the 4 new holes and use it.
JJ, terry said that wouldn't work and to send it back.
   / changing brush cutter out for 6 blade grass cutter #17
First of all, the overall diameter would have to be correct. Second, the hole pattern would have to be centered very carefully, or there would be balancing issues.
I think that they don't make it anymore because they have a finish mower attachment that has three blades. I'm sure that would cost a lot more, but it would work a lot better. A blade setup that big would be likely to scalp and then leave high spots as well.
   / changing brush cutter out for 6 blade grass cutter #18
So,the upshot seems to be that the 6 blade cutter won't work on the 1430 brush cutter.
However, I'm still a little unsure whether it will work on the 422/425 brush cutter. Anyone using it on this rig? If so, how hard is it to change it over. I spoke with Terry about it, and he said it takes a bit of time, and you wouldn't want to do it often. Can any of you add your experience?
Ken
   / changing brush cutter out for 6 blade grass cutter #19
Meg-Mo Systems - Lawn Mower Blades, Replacement Mower Blades, Sharpen Lawn Mower Blades, Mulch Grass
I've purchased a set (3) for my garden tractor, and they are great. Good material/metal, and good craftsmanship. If you really want disc blades for the 1430, Meg-Mo might be able to make some. (But, at what cost...???!!)
Cheers,
   / changing brush cutter out for 6 blade grass cutter #20
wow! talk about a large DISC!
i realize ya asking about other things... but man. first thing that caught me was. is it actually tested. to keep flex down to a min. so when ya out there mowing. the outer edge of the disc does not bow up or down.
second thing that hit me was. do you have the knifes / blades on correctly. what i mean by that is. when the disc spins. will it create the wanted "suction force" to lift grass up to cut it.
i wouldn't think it would matter if knifes / blades were on top or on bottom of disc. just as long as you set them up to cut in correct direction. and created the suction to lift the grass up to be cut. i would imagine being able to place them on top or on bottom of disc. could help you shoot for a higher or lower cut grass. then again i maybe total wrong.
with others scalping,... errr so big of a disc / mowing area. a little hill and all you would have left is dirt on top of that little hill.
if you originally had a square sheet piece of metal. to cut out that large disc. it might be simplier. to measure out a center. drill a hole. through metal. then insert a bolt and tighten it up. with length of bolt sticking up. then hooked a string to bolt. and on other end of string hooked taped a penicl to were you wanted the edge of disc to be cut out. you could make a nice perfect circle.
though with that big of disc. i would imagine. ya initially rough cutting the disc out, and then coming back with a finer detailed metal saw to get a nice clean edge right on the pencil mark. and perhaps taking a grinder and going around outside edges to taking off any sharp edges.
i would imagine after disc is done being cut out and edge work done. string is removed and a good nice straight edge is used (torpedo level for example) and placed up against bolt. to get inital start line done. ((take a pencil and draw clear across the top of disc.))
then move straight edge to other side of bolt. and measure at both ends between line you just drew and straight edge. so both ends are nice and even. and draw another line clear across top of disc.
between the 2 lines. marks the edges of bolt holes for 2 of the knives for blades.
in order to get the remaining 4 knives / blades. you would need to get (duh forgot name of tool) to measure angles. and do a 60 degree angle off of center of bolt. and inital lines you drew.
i got 60 degrees from. there is 360 degrees in a circle. you have 6 knives 360 / 6 = 60 degree spacing from center point between each knife / blade.
once you have your lines drawn out. you can then measure from the outside edge of the disc in. to figure out were the holes need togo for each knife.
once that is all done, then you can drill / cut the center main hole out. using the hole you initally used as a pilot hole for perhaps a whole saw metal bit. if not using that then do same you did to cut disc out, and use a string around bolt. and a pencil taped to end of string to create a nice circle around the center.
once that main big hole in center is done. then measure the inital hole to mounting the disc on. and drill that first. then put a screw in and fasten it onto the drum/deck. so everything is aligned. then use a pencil and/or marker to push through holes and mark the other holes out. ((note got a sharp point ice pick or *duh what is the name of it* to tap with a hammer in each hole. to help ya better identify were center of each hole is. then remove disc and drill the other remaining attachment holes.
above is most likely what i would do making this thing from scratch.
since you already have the disc cut out and that big hole cut out in the center. i might take a piece of plywood. some screws and washers. and fassten the plywood over the main large hole in center. and with multi trial and errors. tap a nail into plywood some. and use a string with a peice of tape on end. till ya found center of the disc. once found tap nail in little further so it holds a little better, double check again you have center of the disc. and ((repeat all steps above. for cutting out disc, ((making it smaller)))), and everything.
diagram is not the best, and i didn't label things. but hopefully looking back and forth of my notes above. and you should be able to see the lines i noted about drawing. and 60 degree angle between each of the 6 knifes / blades.
if anything it might help ya figure out how to measure or align things to get the disc to work for ya.
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
2012 John Deere 6170R (A57148)
2012 John Deere...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2015 Ford Focus Hatchback (A59231)
2015 Ford Focus...
2004 JOHN DEERE 160C LC EXCAVATOR (A59823)
2004 JOHN DEERE...
