3 point hitch to Reese 2" hitch Use RTV to pull Fertilize spreader
   / 3 point hitch to Reese 2" hitch Use RTV to pull Fertilize spreader
You are overlooking the obvious solution. Buy the RTV and a second tractor that doesn't have a backhoe!:)
Steve
Thanks Steve. You had the winning idea/solution.:D I appreciate the other suggestions but here's pictures of my (Steve's) solution.
   / 3 point hitch to Reese 2" hitch Use RTV to pull Fertilize spreader #14
Why not use the hydraulics on the box dump to raise and lower implements?
   / 3 point hitch to Reese 2" hitch Use RTV to pull Fertilize spreader #15
From what I've researched; tapping into the existing fluid flow is a challenge/difficult, on a 500 anyway.
I seen several electric lifts that seem attractive and cost around 5 hundred bucks.
   / 3 point hitch to Reese 2" hitch Use RTV to pull Fertilize spreader #18
I don't have any pictures but I also have one of the Farmboy 3 point hitches from RTV Hitchworks. I also got the snow plow from them and it works great. I especially like that it sticks far enough out in front of the Kubota to be visible.
I have also hooked up a 2 row Yetter plant and a disk harrow to my RTV 1100 and they work perfectly.
MISC TIRES (A54757)
MISC TIRES (A54757)
TEST YOUR BID BUTTON! (A58375)
TEST YOUR BID...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
2015 JOHN DEERE 35G EXCAVATOR (A52709)
2015 JOHN DEERE...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2013 John Deere 27D Mini Excavator (A55973)
2013 John Deere...
