3 point hitch to Reese 2" hitch Use RTV to pull Fertilize spreader
   / 3 point hitch to Reese 2" hitch Use RTV to pull Fertilize spreader
You are overlooking the obvious solution. Buy the RTV and a second tractor that doesn't have a backhoe!:)
Steve
Thanks Steve. You had the winning idea/solution.:D I appreciate the other suggestions but here's pictures of my (Steve's) solution.
   / 3 point hitch to Reese 2" hitch Use RTV to pull Fertilize spreader #14
Why not use the hydraulics on the box dump to raise and lower implements?
   / 3 point hitch to Reese 2" hitch Use RTV to pull Fertilize spreader #15
From what I've researched; tapping into the existing fluid flow is a challenge/difficult, on a 500 anyway.
I seen several electric lifts that seem attractive and cost around 5 hundred bucks.
   / 3 point hitch to Reese 2" hitch Use RTV to pull Fertilize spreader #18
I don't have any pictures but I also have one of the Farmboy 3 point hitches from RTV Hitchworks. I also got the snow plow from them and it works great. I especially like that it sticks far enough out in front of the Kubota to be visible.
I have also hooked up a 2 row Yetter plant and a disk harrow to my RTV 1100 and they work perfectly.
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
Heavy Duty Aluminum Service Truck Bed Rack (A55787)
Heavy Duty...
2002 Bobcat 763 Compact Skid Steer (A56435)
2002 Bobcat 763...
1996 Sunflower 1543-38 Folding Disk (A56435)
1996 Sunflower...
2008 KENWORTH T300 (A58214)
2008 KENWORTH T300...
