Quick Hitches Does Quick Hitches Compromise Lift Capacity?
/ Does Quick Hitches Compromise Lift Capacity? #1
eastexan
Gold Member
TEXAS
Case-International
The reason I ask is that Quick Hitches extend the implement out an extra 4", and have been wondering if there would be a loss in a tractor's lift capacity? Or would it just effect the center of gravity? Or neither?
I've noticed that a tractor's lift capacity rating is usually measured at 24". Using a QH would extend it out to 28". It sounds reasonable to me that the farther out you go, the heavier it becomes. And, if the front end of the tractor was already light with a heavy implement, then adding a QH might cause you to have to add some front weights.
What are your thoughts? :confused:
/ Does Quick Hitches Compromise Lift Capacity? #2
You are correct, absolutely they do affect lift capacity since they move the load further away. But how often are you/we lifting at near capacity on the 3PH? Most users have rear blades or box blades that weigh less than half of what a typical 3PH can lift.
/ Does Quick Hitches Compromise Lift Capacity? #3
It really doesnt effect the capacity that much. But you are correct that it does change the center of gravity and make more weight required up front.
A 3PH is a modified parallelogram linkage. That means that what it "can" lift doesnt diminish much at all the farther back you go. The real limiting factor is keeping the front end down.
And if you are talking about the case 385 you have in your profile, according to t-data, it can lift 2150lbs @ 24" back. I cant imagine you are trying to lift anything even close to that:confused2: So just add some more weight up front if required and all is good.
/ Does Quick Hitches Compromise Lift Capacity? #4
3PH capacities are frequently given at 24" aft (as ws written). Some are also give at the "eyeball" of the link.
Figure a QH weighs 60 lbs...that weight would have to be factored in on the lifting capacity.
However, I can't see this having too much effect for most users. That 3PH capacity is a lot more then any of my implements weigh and I don't think I'm alone in that situation.
/ Does Quick Hitches Compromise Lift Capacity? #5
It would be barely measurable if that capacity was from 24" rearward of the lift arms. it would be a little more a factor if the spec was right at the lift arms.
It's about leverage ratio, so yes it would reduce the capacity but not by a noticeable amount.
Anyway, this usually happens before the 3pt fails to lift, at least from my experiance :laughing:
/ Does Quick Hitches Compromise Lift Capacity? #6
That happened to me once.
I always installed the loader, then the ballast box...but one time I hooked up the ballast box first (on my old 790...not too long after I got that ballast box).
Needless to say, the 3PH didn't lift, but the front end of the tractor sure did!!
No damage and I lowered the tractor as soon as I felt the front end come up (front tires probably never got more then 8-10 inches off the ground).
Kind of surprised me...I'd frequently lifted a 60" Befco RFM (450 lbs, per the Befco site) with no front ballast. I guess that extra 200-300 lbs in the ballast box was enough to do the job though...
/ Does Quick Hitches Compromise Lift Capacity? #7
I think the reduction can be calculated using moments taken about the connection point of the horizontal lift arm at the tractor. I used rough measurements from my Kioti and the following assumptions:
- lift capacity = 2,000 lbs
- vertical lift arm distance from pivot = 1.0'
- 3 point end hole distance from pivot = 1.25'
- implement weight 2' behind 3 point arm end = 2.0' (= 4.25' from pivot point)
- quick hitch adds 4" (0.33') to distance from the pivot point (= total distance of 4.58')
Ignoring the quick hitch weight, the lift capacity would be reduced to 1,855.9 lbs from 2,000 lbs. To account for the quick hitch weight one just has to calculate its moment 2.25' from the pivot point and add it to the moment due to the implement.
To calculate the additional front weight required to move a 2,000 lb load 4" farther back from the hitch one would calculate moments using the rear axle as the pivot point. On my Kioti that would be about 4.5' back to the centre of the implement and 8' forward to the grill guard. The calculation suggests 82.5 lbs would be required to keep the tractor front/back balance the same as before.
The attached .pdf shows the calculations.
  • 3pointCalc_0001.pdf
/ Does Quick Hitches Compromise Lift Capacity? #8
I like the way you did your homework, I figured there would be a formula to use.
I'm not bright enough to check your calculations, but assuming you're right that's about 7% loss. Not bad, but more than I would of guessed, especially for using the 24" rearward position for the capacity.
I believe the percentage would be higher if calculated using the lift arm eyes as the starting point ??? Or is it the other way around?
JB.
/ Does Quick Hitches Compromise Lift Capacity? #9
:thumbsup:Yes./\
From your description the lift numbers will be wrong with a std 3pt type QH, but correct for Pats QH. The preservation of the articulation points of the //ogram linkage in the former is the reason it will give superior lift. The lift loss with a std QH would be around 10% more than the weight of the QH. [There are a couple threads that have dealt with this in the past year or two.] ... Your front/ back balance concept is sound however.
larry
/ Does Quick Hitches Compromise Lift Capacity? #10
JB.
Wrong, wrong, and more wrong.
The 3PH is not a simple lever. And thus the calculations and rotation about the moment cannot be used.
Disclaimer: the 3PH calculations do NOT account for front end weight. It is assumed that you will have enough weight up there and that the components are strong enough to take the load.
That said, the 3PH can be adjusted in many ways with the toplink. Either by its length or its mounting position.
But if your particular tractor lets you mount it to for a perfect parallelogram, there will be NO loss in lift capacity at ANY distance rerward. (again, not accounting for front ballast or strength of components).
All tractors are different though. So how far they deviate from a true //ogram will affect the outcome. The farther from // they are, the greater reduction in capacity. But still not as much reduction as just trying to use a simple lever formula.
Rest assured that what I am saying here is accurate. We have been down this road (myself and spyderlk) before here on TBN. There is a few other threads where this is discussed to death at length.
/ Does Quick Hitches Compromise Lift Capacity? #11
:thumbsup:Yes./\
larry
You posted while I was in the middle of typing my reply, so I guess you beat me to it:confused2:
I was just getting ready to drop you a PM bacause I was afraid I might need a little back-up. glad you are here:D
/ Does Quick Hitches Compromise Lift Capacity? #12
My thinking is that quick hitches are wrong. Real farmers and tractor operators know how to easily attach cat. 0, 1, 2 implements, without the need for a crutch. I.e. a quick hitch. The quick hitch is going to downgrade the performance of the tractor/implement setup. A buddy I know, bought an L4200 and a Q.H. Before long the Q.H. was discarded, Another ~$300 wasted.
Quick hitches were designed for cat. 3,4, and 5 size implements,
This ought to ruffle some feathers....:D
/ Does Quick Hitches Compromise Lift Capacity? #13
;) Yeah. It was hard to get it thru that 1st time. But now that its on the forum we dont have to start from scratch. Just search it and attach a link. "//ogram" will find it well I think. ... http://www.tractorbynet.com/forums/...s/145738-conversion-factor-3-point-hitch.html
:thumbsup:
larry
/ Does Quick Hitches Compromise Lift Capacity? #14
/ Does Quick Hitches Compromise Lift Capacity? #15
I don't know if I should be glad or sad that I missed out on those discussions :laughing:
But I will take your word for it for now, especially since I never even heard some of those words you guys are using before, let alone know what they mean.
Just seems a no brainer that moving weight away from the point were it is lifted would excert greater force on the lift point, reducing the amount of weight that could be lifted.
I got enough to worry about with the end of the world and all, to worry about my 3 pt hitch or a parallelogram moment :D
What the heck is a moment anyway?
JB
A couple years ago, I used my Ford 3000 to move my implements about 300' to another location on my property, and thought the simplest thing would be to use the boom pole.
I didn't have a problem until I picked up the Bushog cutter. I had no steering since the front end of the tractor just wanted to rare up and skim along the top of the ground. So I kept the load low until I was able to hook the chain to the middle eye of the boom. Then there was no problem after that.
Since then, I got to wondering that if I hadn't used the QH maybe there would have been just enough weight reduction to have made it without having to stop and rehook.
It was no big deal, since I could have either put some weight on the front or else just hooked it to the 3ph. But it made me curious as to what effect that 4" difference woud make.
Thanks everyone. :thumbsup:
/ Does Quick Hitches Compromise Lift Capacity? #17
Moment - Tendency of a force to rotate an object about an axis.
An example would be a hydraulic cylinder used to dump and curl a loader bucket. The cylinder is the moment force. The distance between the bucket pins is the moment arm. The lower bucket pins are the axis of rotation. The object subject to the moment force is the bucket and the load in the bucket.
The moment is the force exerted by the cylinder.
(Area of the cylinder piston x the hydraulic pressure exerted against the piston = the moment).
/ Does Quick Hitches Compromise Lift Capacity? #18
Ya ruffled mine, I ain't giving up my QH. And definitely no money wasted :)
I always thought for HD constant ground contact implement use, a QH wouldn't be the best way to go, But I guess what your saying is they're more suited to the big stuff.
JB.
:thumbsup:
larry
Wow! Several of you guys posted before I got my reply typed out. :confused2:
I hadn't seen that point being discussed here before, even after using a search.
I'll read that thread. But what you all are saying about "moments", etc., just flies right over my head. :laughing:
Thanks for the link.
/ Does Quick Hitches Compromise Lift Capacity? #20
I got a challenge for you guys.
Lady GaGa is going to be on the season finale of SNL tonight, come up with a formula that figures her, it, that out. :laughing:
JB.
2013 WACKER NEUSON LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2201SFL (A64553)
2201SFL (A64553)
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
Unused 2022 USA Attachments EB-618 18in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2022 USA...
2013 Ford F-150 Crew Cab Pickup Truck (A66736)
2013 Ford F-150...
