2520 tach
/ 2520 tach #1
PCABE5
Wisconsin
John Deere 4066R Cab and loader
Anyone ever have theirs quit? Started mine tonight and no tach.
/ 2520 tach
I pulled the dash and the cable walks itself into the tach until it disengages. If I hold the cable with pressure it spins. Bad cable I'm betting.
/ 2520 tach #3
Sounds like you found it! Judging that it's a 2011 tractor it must be under waranty.
/ 2520 tach
Not even a month old. I'll have to call tomorrow. If nothing else I'll fix it if they have the part.
/ 2520 tach #5
What happened with your tach not working? What did you need to replace? My 2520 (2011 with 60 hours) just had its tach quit tonight. Under warranty for sure but wondering what's involved as getting the tractor to the dealer is a big deal for me.
/ 2520 tach
Mine was the tach cable broke. Disconnected the cable from the tach and it didn't move when the engine was running. Cable would be easy to replace.
/ 2520 tach #7
My 2520 tach & hour meter both went belly up... Are they both mechanically driven by the same cable?
Thanks!
Best regards, Pete Hodgkins, Casa Grande Az
/ 2520 tach #8
:welcome: to TBN
You can look up the part no. in jdparts.com (free registration) and google the part no. for availability. Also can see what it is connected to in the schematics shown.
2013 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2013 ALLMAND...
2022 JCB Fastrac 4220 217HP 4WD Agricultural Tractor (A66734)
2022 JCB Fastrac...
2014 CATERPILLAR D6T XL HI- TRACK CRAWLER DOZER (A65056)
2014 CATERPILLAR...
2005 Sterling 9500 Truck (A66736)
2005 Sterling 9500...
CAT 631C Lift Cylinder (A68134)
CAT 631C Lift...
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
