Lifting logs with a SCUT bucket
/ Lifting logs with a SCUT bucket #1
sw18x
Looking
Hi all
As I've already posted elsewhere, I'm in the process of buying a BX2360 (wife conceded!). We have an outdoor woodburner and get chunks/logs dropped off occasionally from a tree service. A big selling point on the BX was having the ability to lift the heavier pieces onto the splitter, saving my back for better uses. Some of these pieces are big enough for one person to handle, just very heavy, some pieces take 2, a few are too heavy for even a couple guys (maybe 300 - 350 pounds, these pieces still need to be moved around the yard though they might not end up on the splitter itself). The dealer is welding two chain hooks on the outside of the bucket (he discouraged me from having the hooks put on the top). I've been trying to plan out how I can use the FEL most efficiently for this task. So far my ideas are:
- loop a chain from one hook to the other, with the slack hanging under the bucket. Get some mombo screw in hooks (similar to the kind that screw into walls for hanging stuff), predrill the biggest logs, screw in the hooks, and lift the logs from the hook using the chain.
- run the chains across the hooks, drop the bucket in front of the log, roll the log across the rest of the chain, bring the hook ends of the chains back up across the top of the log and fasten to the chain near the top of the bucket, thus cradling the log with the chain.
- buy a set of pallet forks, roll the logs onto the forks, curl the bucket so the log rests back on the bucket and lift.
Another consideration is using the FEL to lift chunks/logs onto the back of my pickup truck, in which case I don't think I have enough lift on the FEL to do it if the log is hanging below the bucket.
What do you think? How do you guys perform similar jobs? Looking for any feedback here (except "you bought the wrong tractor for this job!")
Thanks, these forums are great to read and lots of helpful info.
/ Lifting logs with a SCUT bucket #2
Bolt some forks to the bucket. Also bolt some type of restraint device on the back of the bucket to keep them from sitting on your lap.:D
/ Lifting logs with a SCUT bucket #3
I got QA pallet forks and tried them out this last weekend. THey work great for logs! :thumbsup:
/ Lifting logs with a SCUT bucket #4
First, don't forget you'll need rear ballast of some sort!!
I like the forks idea too (and definitely heed Egon's advice about
Might save you and might save the hood of your BX2360.
As far as how to hold the logs...you might want to consider using straps rather then chain...bit easier to work with for lighter loads.
/ Lifting logs with a SCUT bucket #5
Perhaps cutting them into smaller pieces would work.
/ Lifting logs with a SCUT bucket #6
When I bought my tractor, I never thought I'd use forks so I didn't get the quick attach. I do have chain hooks which I use. I soon bought a set of clamp on forks which I now use enough so that I wish I had gotten the quick attach and a set of real forks. If you're able, do it now and you won't regret it.
/ Lifting logs with a SCUT bucket #7
I've been able to move some logs and stumps just by using a piece of chain as a choker and wraping it around the bucket, adjusting the length with grab hooks. It takes some time to hook up so having forks would be a lot better if you have numerous ones to move. I'm lazy and find I like doing everything from the seat. I do plan on building a set of forks but have been too busy to get to it yet. You will need some sort of guard on the back of your bucket if you plan to move firewood and don't want your hood all banged up. At 50 hours my Massy GC 2610 has at least a dozen dents in the hood from firewood falling out when going over bumps.
/ Lifting logs with a SCUT bucket #8
hmm -- did you already get a wood splitter? there are some splitters that can move to upright position. I really think you should invest in a boom pole and logging tongs instead of using a BX fork all the time. safer and easier and better on tractor no matter whats the model is. You can literally lift more with 3 pt then with bucket.
/ Lifting logs with a SCUT bucket #9
I would use my QA forks, it has a nice mast to keep the log from rolling on the tractor, but of course try not to lift it too high to begin with to transport it, but I realize you probably dont have a QA. So a set of clamp on or chain on forks would probably get you by, as for chaining up the log, sure you could probably make it work, but seems like a lot of bother if you have many logs to move. And as for dumping the logs in the back of a pickup, seems to me any method is going to make a heck of a bang and dent in the bed of the truck. to set them over the side. I am not envisioning how that would work out for you. If you were loading short pieces (under 4 foot) then load them from the tailgate, then I could see that working, with a helper to carefully roll them into the bed. Well if you had a QA and some hydraulics.. then a grapple could probably make short fast work of loading logs, but a good set of forks can load stuff pretty quickly also.
James K0UA
/ Lifting logs with a SCUT bucket #10
The BXpanded forks are very nice, lightweight and relatively inexpensive. I have moved a lot of logs with my BX24 using the BXpanded forks. The fork brackets will hold additional bucket hooks as well. (with the forks removed)
Matt.
/ Lifting logs with a SCUT bucket #11
Hi all
This is how I get the big ones on the splitter, it has worked very well for me. A little time consuming perhaps but I don't want to move too fast with the heavy ones.:)
/ Lifting logs with a SCUT bucket #12
Hi all
I don't understand why he is against hooks on top ...but I would say having only two hooks, one on each side, is an invitation to disaster ...or a requirement for always using twice as much chain as otherwise required.
I have found it very (very) important to have any (heavy) chained load centered...otherwise raising the bucket raises the opposite rear wheel, which can be very disconcerting (and dangerous, depending) ...and, I have a heavy tractor, big loaded turfs, and usually an implement on the rear.
I'd discuss this again with the dealer
/ Lifting logs with a SCUT bucket #13
Hi all
Spend money (-:
At least add a grapple to the bucket.
Better yet get a separate grapple.
Is this a li'l tractorette ? (I don't know the Kubota product line)
Does it have a hoe ? If so and if that has the capacity to lift what you want to move around - add a thumb to the hoe.
/ Lifting logs with a SCUT bucket #14
Hook at the center can result in a bent bucket (unless you brace it...been many many threads on that).
Hooks on the ends distribute the load (on the bucket) better and you can use one chain (if it's long enough) by running through those outer hooks, then to the item you're lifting. Wish I had a pic since that would show the rigging a lot better then I can explain it.
My bucket has 3 hooks...one in the center (for light work) and two outboard (heavier stuff, obviously). Mine are positioned the same as Veresjwv's are (pics in post #11).
But I agree with you on NOT using one outboard hook to lift a load.
/ Lifting logs with a SCUT bucket #15
Since you're talking lifting onto the splitter I'm assuming you're already cut to length. Use tongs or something like this Log Grabber alternate to tongs
These hooks are used on wreckers & may be available for less $. Or you could cut the handle off a couple of pulp hooks & weld on some chain for under $100.
If you have a quick detach bucket you could get a fel mount short boom pole & with wood would still weigh less than a bucket full of dirt & would have better reach.
Also keep in mind that lifting from one end mounted hook places tristing force on your FEL arms. Bend buckets are easier to fix than twisted loaders. When lifting from corner hooks with the chain at 45 degree angles to the load doubles the effective load on each chain. Reinforce your bucket for a center hook or get a quick attach boom pole/forks. MikeD74T
Thanks for all the input.
Just to clarify: what I'm planning on doing sounds similar to what RoyJackson described: string a chain across both outboard hooks, then center a chain with tongs coming off that. Already using the neighbor's splitter and have a design for a horizontal homebuild ready to go...Reg you're already hurting my feelings and my "l'il tractorette" hasn't even arrived yet. I admire all the big boys but my property doesn't justify anything bigger than a subcompact. I had to laugh at the smart@ss comment about cutting smaller logs, you're right that would seem to be the easiest solution:) But the situation is, the tree guy drops off what he likes and I don't turn anything away when it's free wood. I only have an 18 inch bar on my saw and it's a bigger pain to cut a 24" or 30" log with a saw than it is to dump it on the splitter and let the 4 head take care of it that way. As far as loading in the truck, I only have a 5 foot lift on the bucket so loading on the tailgate is exactly what I had in mind. Still need to figure that one out, because with the log tongs there's no way I can lift the bigger pieces that high. It's not a necessity now to load the truck, but one of the local surgeon's gave me a green light to go down to his yard and take away the bigger pieces he's got there (again, I can cut those pieces up with the saw for transport but even a chunked up 30" piece is a hefty lift into the pickup). I agree on the grapples, but I used up all my points getting the wife to agree to the tractor to begin with, it's been made very clear that there will be no expensive implements added on any time soon.
Best place for a heavy duty set of tongs? Straps for logging? Any more pics or ideas would be appreciated.
/ Lifting logs with a SCUT bucket #17
getting big pieces into the truck: (1) its amazing what you can haul up an inclined plane...make/buy one, then rig a pulley at the front of the bed, behind the cab and with winch rope, pull it up the ramp by backing tractor up ... (2) buy a small HF (ATV) winch and mount in truck bed, pull up ramp; (3) push up ramp w. bucket; (4) make a "loading dock" to get your tractor high as/higher than the bed...or, your truck lower
Just thinking out loud
/ Lifting logs with a SCUT bucket #18
sw18x " string a chain across both outboard hooks, then center a chain with tongs coming off that.'
Be very careful with that. Sideloaded hooks can release a chain quite easily if you bump the load on tailgate or splitter. MikeD74t
/ Lifting logs with a SCUT bucket #19
sw18x
I have used my logging tongs to lift large rounds onto the splitter, but found that the tongs and chain would get in the way of splitting.
What I do now, is have the firewood blocks cut to length with the chainsaw. Then I roll one or two of them into the bucket and move the bucket to the splitter with the lip at splitter height. Then I can pull a block at a time off onto the splitter. Half of the first split goes back in the bucket, while I either hang onto the other half or let it drop to the ground.
I find when working alone, that raising the large rounds in the bucket and working out of the bucket works most efficiently for me. Don't have the bucket and chain and logging tong hanging around over the splitter when I'm splitting, as it is not as safe as I'd like it to be.
Another option I've used is to put an empty pallet on my forks, and roll some rounds on the pallet and use that pallet as a work platform at splitter height.
For any very large rounds, or knarly crotches, I just bust them down into smaller pieces using the chainsaw. It is prolly as fast as raising them onto the splitter. ;)
/ Lifting logs with a SCUT bucket #20
SX18x,
I have a BX22 with the FEL & BH. I put a Bro-Tek Thumb on the BH & splitting is now a breeze. Definitely the way to go if you can. Forks on the Bucket if not. The advantage with the BH is being able to pick it up and shift it around until it will sit on the splitter, less of an issue if your splitter is vertical. My :2cents:
T-Man. :cool:
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
2023 Case TV450B (A62177)
2023 Case TV450B...
Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
Hydraulic Auger...
3 Brake Drums (A62613)
Case SV280B (A62177)
Mercury Verado AMS 350 (A61574)
Mercury Verado AMS...
