tractor won't start
/ tractor won't start #1
pilonandr
jd l130 23 hp
hi there my l103 jd with 23hp kooler dont start i did change plug andfilter and oil i do have poor fire ,600hrs on tractor ,hepl neede
/ tractor won't start #2
:welcome:
What does "poor fire" mean?
That it doesn't start, or that it starts and runs poorly?
/ tractor won't start #3
Hearing more and more use fresher gas,and that seems to be the answer.
/ tractor won't start #4
I had a problem starting my JD 165 after doing the same things you have described. I ended up taking it to my mechanic and he noted that it had significantly reduced compression. I don't know the hours it had on it, but since it is a 1988, I'm sure it was in the hundreds. You might want to see if your unit's compression. Let us know if you get it running, or if you find out what the problem is. Good luck.
/ tractor won't start #5
is the gap on your plug correct? did you use stabelizer in your fuel, as well, what is the ethonol % in your fuel
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lift (A61568)
2010 Ari Hetra...
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
Kuhn FC400RG (A60462)
Knapheide Service Bed (A61165)
Knapheide Service...
