Swisher trimmer....your thoughts?
/ Swisher trimmer....your thoughts? #21
I have an Ariens walk behind trimmer, several push lawnmowers,several brushcutters/trimmers, a bush hog and a pond. If I had to only pick one for around the pond I would pick the cheap push lawnmower, followed by the brushcutter. A cheap lawnmower is like a rental pickup truck -- it will double as a humvee when required:eek: The brushcutter is just versatile and works great but is tiring
I had to modify my walk behind by drilling the wheel mount brackets to raise it since the original ground clearance made it next to usless on anything but a manicured lawn. Once I modified it, it became a weed eating wonder and I get much more use out of it maintaining paths and around the pond. The line is .155 so it lasts a fair amount of time and is easy to change. I bought mine used and figured if worst came to worst I could use the motor in a lawnmower:) -JMHO
I covet those $50, previous year's clearance/return, 22" Walmart push mower that you can snag sometimes in early spring when they're putting out the seasonal garden stuff. I got a brand new $350 roto-tiller for $100 a few years ago. I kept the clearance tag on it...wear it like a badge...:laughing: But the small push mowers are really no good for tall grass obviously.
Just to verify you were talking about a walk behind trimmer in the last paragraph of your post?
/ Swisher trimmer....your thoughts? #23
Yes I was talking about the walk behind trimmer in the last paragraph.
The other thing I have seen done is cutting away the front skirt of a push lawn mower to act as a long grass cutter -- may not appear as the safest thing but does work well for chopping weeds down:thumbsup:
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
Forks and Frame Mini Skid Steer Attachment (A61572)
Forks and Frame...
2007 International 4300 Bucket Truck 55' (A62613)
2007 International...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
