Buying Advice CT235 bobtach pallet frame and forks
   / CT235 bobtach pallet frame and forks #11
Milkman, you got a picture of the set-up mounted. Would love to see it....................
No pics yet. I should be able to post a pic here over the weekend for you though, when it stops raining.
   / CT235 bobtach pallet frame and forks #12
Milkman, you got a picture of the set-up mounted. Would love to see it if you do.
As for Everything Attachments, don't those forks mount on the bucket or do they mount to the bobtach after removing the bucket?
The mount on the Bobtach after removing the bucket.
   / CT235 bobtach pallet frame and forks #13
You should check the forks at Everything Attachments. Good quality, good price and not too heavy.
+1
COMPACT X-TREME DUTY Shaft Mounted Pallet Fork
Nice and light, strong. Inexpensive. Both QA and pin on styles available. Easy to move them around without a machine when they are not mounted. They have held up well to abuse. EA below has good pictures.
Construction Attachments 42" Compact Tractor loader Pallet Forks CAL-1PFCMPSM42
I ordered mine from Everything attachments and it was delivered to a freight terminal 3 days later (from North Carolina to California !!). Great guys to work with and a site sponsor.
Steve
   / CT235 bobtach pallet frame and forks #14
I paid 550 minus 100 (with my Bobcat discount coupon last year) for a Bobtach 42 inch pallet fork set
:thumbsup:
   / CT235 bobtach pallet frame and forks #15
Here is what my CT335 forks look like.
   / CT235 bobtach pallet frame and forks #17
I can reccomend the Construction Attachments QA Compact Forks from Everything Attachments. They weigh less than 300 lbs are fully adjustable to any width and work well. They are the right size for my tractor with about 1000 lbs of lift capacity, and they are rated for 1800 lbs. they are light weight, and weigh less than the bucket they replace. They have a nice mast, and work good for logs and brush as well as pallets. Watch their video and you will want some :)
James K0UA
Ford N Series Tractor (A59814)
Ford N Series...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
2007 FREIGHTLINER COLUMBIA TANDEM AXLE SLEEPER (A59575)
2007 FREIGHTLINER...
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
FUEL CELL (A58214)
FUEL CELL (A58214)
