Hydraulics lifter assembly KAMA TS254C
/ Hydraulics lifter assembly KAMA TS254C #1
lakespirit
Idaho Panhandle
2004 KAMA TS254C
Anyone know what the function of the parts numbered 42 to 49 are on page 99 of the parts catalog?
I cannot get my system working and have taken the entire lifter case off and have removed the cylinder and distributir assembly looking for worn or broken parts. So far haven't found anything. How would you go about checking each hydraulic line and cylinder in the system for a clog?
/ Hydraulics lifter assembly KAMA TS254C #2
When I traded mine, the manuals went with it. Any chance you can scan a copy of that page and upload it here?
//greg//
/ Hydraulics lifter assembly KAMA TS254C #3
//greg//
Here it is. Thanks.
/ Hydraulics lifter assembly KAMA TS254C #5
That's the draft control feedback linkage
//greg//
What's it do? How should it be set?
/ Hydraulics lifter assembly KAMA TS254C #7
First off it's only used in conjunction with ground engaging implements; like plows, box blades, middle busters, rakes, etc. When the implement wants to dig too deep, it exerts a pull on the toplink bracket. That extra pull on the toplink transfers to the draft control linkage, which in turn raises the rear lift back to operating depth. To the right of the operator seat are two levers. The inside lever you already know raises and lowers the three point hitch. The outside lever allows the operator to set that operating depth. It sets the sensitivity of the draft control linkage, which in turn tells the rear lift to raise the ground engaging implement back to operating depth if/when it starts to dig too deep. When draft control is not required - which is typically most of the time - the outer lever should always be in the full up position.
//greg//
Learned something new again!
I cannot keep from dumping gallons of hyd oil into the gear box. I replaced the oil seal at the the pump shaft. I have destroyed two of the seals so far. The spring in the seal winds up coming out and winding around the shaft. Whicj direction should the seal face? Should the "u" shaped side be toward the pump or the other way. How many lbs of torque should I use to tighten the bolts that mount the pump to the gear box assembly?
//greg//
/ Hydraulics lifter assembly KAMA TS254C #10
In my experience, one side of that U you describe is a hair taller than the other. I seem to recall that's the side the printing's on too. Unless there are instructions to the contrary, I typically face that side out. Obviously then, the other side faces the grease/oil that you're trying to seal in.
But I don't understand some of your wording. First off, which pump; front or rear? Second, why would you be "dumping gallons of hydraulic oil" into a gear box? Lastly, how did you determine what size replacement seal to purchase in the first place?
//greg//
The gear box is under the hydraulic fliud tank that has the rear end. The hyd. fluid must be getting through the oil seal through the bearings that hold the shaft from drive to the rear hyd pump.
/ Hydraulics lifter assembly KAMA TS254C #12
The "gear box" to which you refer is actually the rear differential housing. You don't put hydraulic fluid into the differential housing. Hydraulic fluid goes into the sump through a fill/vent behind the seat, gear oil goes into the differential housing through a fill hole in front of the seat. Please clarify what you're putting where.
It sounds like the seal that you're referring to is the aux PTO shaft seal. It seals gear oil into the differential housing, not hydraulic fluid. Please clarify what's leaking from where; hydraulic fluid from the PTO pump, or gear oil from the differential housing.
//greg//
I am losing hydraulic oil into the rear diff, but can't figure out what's going on with the seal. It is the correct size as stated in the parts manual. The gear oil is now diluted quite substantially form the hydraulic oild leaking into it. If I understand you, The shaft that drives the hydrualic oil pump is the PTO aux shaft?
/ Hydraulics lifter assembly KAMA TS254C #14
No reason to believe your 254 is configured any different than my 354, so yes. The permanently mounted rear hydraulic pump is indeed driven by the aux PTO shaft. But it's only a mechanical connection. There should be no reason that hydraulic fluid is getting into your rear differential housing that way. What I don't know is if your hydraulic reservoir under the seat is a one piece sump. If yes, there's no way for hydraulic fluid to get in that way either. If no, you'd have to remove the seat, then remove the sump to determine if that might be the source of the leak. Obviously, drain out all the hydraulic fluid first.
//greg//
I've had this apart for some time now. There are two bolts and two studs on bottom of resevoir sealed with o-rings. They don't leak, I have replaced them and filled with fluid and allowed to sit for a couple days. It's only when I put it back together and run the engine that the fluid gets into the rear differential.
/ Hydraulics lifter assembly KAMA TS254C #16
The auxilliary PTO shaft goes straight through the differential housing, through a bearing and out the back. There is no internal seal and when the hydraulic pump blows it's seal it pumps oil around the blown seal through the bearing and into the differential housing, thus filling the differential with hydraulic oil.
The correct positioning of the lip seal in the hydraulic pump will have the face of the seal (part number side) facing out, spring and lip facing in to the pump. Seal face should be flush with the pump housing.
Anyone know how to adjust the pressures inside the hyd sump? Since I have replaced my seal with the size recommended and stil am leaking (when not flooding) into the rear diff, should I go a size smaller on the I.D.?
/ Hydraulics lifter assembly KAMA TS254C #18
There is no internal pressure to adjust, the sump is little more than a holding/cooling reservoir. But there's something about this problem of yours that doesn't compute. I'm guessing there's some part of this story that you're not telling us.
And every seal you need on that tractor is specified in the TaiShan parts manual. Is that what you mean by "the recommended seal"? Or have you stuck something else in there. If push comes to shove, I've still got an entire set that should have every grease/oil seal and O-ring you'd ever need for that tractor.
//greg//
/ Hydraulics lifter assembly KAMA TS254C #19
No, it shouldn't. I say shouldn't, because there's an oil seal where the aux PTO shaft passes through the housing. Maybe even two, but I don't have my books anymore. So even if the PTO pump seal is leaking hydraulic fluid, it still shouldn't get past the aux shaft seal to mix with the gear oil.
There's something else going on here that we haven't been told yet.
//greg//
/ Hydraulics lifter assembly KAMA TS254C #20
The auxilliary PTO shaft is high enough in the differential housing that it doesn't need a seal, and if perchance there was a seal there it would be facing such as to keep oil IN the housing, thus allowing pressurized oil to pass freely into the housing. This is the same setup that is on my dozer and I know that it will fill the housing with hydraulic oil in a heartbeat. I speculate that there is a serious restriction on the pressure side of the pump causing the seal to blow, quite possibly the internal "figure-8" seals are blown or there is too much clearance between the gears and end plates. Also, the end plate bearings could be bad/oversized through wear.
