oil filter for L3000 dt
/ oil filter for L3000 dt #1
leonardtlovejr2
kubota L3000
hi,i am new to this site i have a L3000dt and i am looking for a oil filter maybe a fram or wix but i can not find what filter to use.any help would be nice
/ oil filter for L3000 dt #2
Have a L3000 DT also. Have always bought my oil filters from the dealer Leonard.
I own/manage a small auto repair shop, 5 employes, including myself.
At anyrate sometime you just cannot beat the OEM filter, often times the drain back valves and filter media are superior on the O.E.M. filters.
Before I started my shop 26 years ago I always used Frams on my cars. Have since seen information on websites which test filters indicating they are one of the poorest performing filters you can buy.
Ford techs have been reporting damage to the newer, 2002 up, V8s with the hyd. cam-phasers due to cheap oil filters breaking up and lodging debris in the internal pasages causing camchain, cam and follower wear and engine noise culmanating in the destruction of the engines.
I am not condeming all aftermarket filters but I am pointing out unless you KNOW the aftermarket filter you are using is a quality unit why risk it.
Ditto for air filters. Know a fellow who some years ago lost the motor on his John Deere field tractor due to a glue failure on a aftermarket air filter.
My closest dealer is 50 miles away, I simply order them over the phone and have them UPS delivered.
/ oil filter for L3000 dt #3
WIX Oil filter #: 51311
WIX Filters : Filter Look-Up
Part Number: 51311
UPC Number: 765809513112
Principal Application: Volvo (92-99), Kubota, New Holland, Volvo Trks + Buses, Mahindra Tractors
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.372
Outer Diameter Top: 3.661
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 16
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=8/21
Burst Pressure-PSI: 331
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
/ oil filter for L3000 dt #4
Wix=Good filter. I use them on the tractor and my supercharged Mustang GT.:thumbsup:
2024 SILVERBACK 53CH3A TRI/A CAR TRAILER (A59914)
2024 SILVERBACK...
Hickory Lumber (A65640)
Hickory Lumber...
3 Bottom Plow (A65640)
2015 PETERBILT 567 6X4 T/A DAY CAB TRUCK TRACTOR (A66091)
2015 PETERBILT 567...
2014 DRAGON  130BBL VACUUM TRAILER (A65643)
2014 DRAGON...
2020 KENWORTH T60 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 KENWORTH T60...
