DK35 Fule Filter Cross
/ DK35 Fule Filter Cross #1
aje3721
Does anyone have the fuel filter cross for the DK35? For that matter if you do, do you have it for the hydo and the engine oil? I got some crap in the tank and a no start, air all over the place, no fuel filling the bowl with the petcock on, issue...
Can't complain about the ol girl; first time she sat out dead in four years...
Thanks Vince!
Any luck on the hydro filter or isn't there an option yet?
/ DK35 Fule Filter Cross #4
I am running am Kioti hydraulic filter.I have not found the cross # for it yet.
/ DK35 Fule Filter Cross #5
The cross numbers are nice but the manufactures filters are so reasonably priced, I always use them. When I make a trip to the dealer I buy 4 oil, 1 Hyd, and 1 fuel. This gives me a filter supply that will last between Hyd fluid changes, as I change my oil filter with each oil change.
/ DK35 Fule Filter Cross #6
Since you mentioned fuel, I figured I show off my free fuel funnel. Had an old bottle of Listerine and cut off the bottom. Fits in the tank perfectly and allows me to start filling without spilling.
/ DK35 Fule Filter Cross #7
I've thrown all my CARB compliant containers away;never spilled fuel until I used them. Thankfully, I still have a few of the oldie/goodies left. D*** the greenies
/ DK35 Fule Filter Cross #9
I think we sell fuel filters for around $6.50 or something and oil filters are just over $15.00. Unless you don't have a local dealer, or they are robbing you, I wouldn't think going to a Napa filter is really worth it.
I think both of those prices have basically stayed around there since we started selling Kioti's 6 years ago.
/ DK35 Fule Filter Cross #10
Maybe not for for oil and fuel filters but, $86. for a Hydro filter for a CK20HST from the dealer compared to about $12 from NAPA I'd say that's worth it.
/ DK35 Fule Filter Cross #11
I have not found a Hydro filter at NAPA? What is the cross over number??
/ DK35 Fule Filter Cross #13
With respect to the fuel filter.
The WIX p/n 33507 is the same p/n used on my Kubota. Surprisingly Kubota is relatively cheap for this filter. It lists for $3.60. The P/N is 15521-43160. I found the dealer to be cheaper than other sources... At least in my area.
/ DK35 Fule Filter Cross #14
Post the OE number and I can cross it at work.
The number I have is T2195-38031 CK20hst Hyd HST Filter.
It is not that they are expensive for the ck20, just convenient if they were available locally.
/ DK35 Fule Filter Cross #15
Not sure if that is the correct part number. There is a dealer from Texas who has these filters posted on ebay along with pictures with the part number T2360-38031 and has them discounted to $82. and change, to me that is not cheap, the last one I bought was around $70. but it's been a couple years. The Wix cross is 51663 drop the 5 and that is the NAPA number, Baldwin is BT26010, with those numbers you should be able to find others.
/ DK35 Fule Filter Cross #16
I agree, that is worth it.. make sure the aftermarket filters are designed for oil flow to go the proper direction. We had a customer who went to Napa to match up an engine oil filter, it looked to be the right one, ran it for less than an hour, starved the crank and took out the engine. Than again, that was on a TaskMaster and now he has a Kioti since we parted his thing out..
/ DK35 Fule Filter Cross #17
If you don't have a dealer near by, call your favorite Kioti dealer and have them drop ship the filter and any other parts you need right to you. That's what mine does for me, always has.
1000 GALLON ELEPTICAL NURSE TANK TRAILER (A64276)
1000 GALLON...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2016 Kubota L3301 (A62177)
2016 Kubota L3301...
2002 Suncoast 18ft T/A Enclosed Trailer (A61574)
2002 Suncoast 18ft...
2023 Kubota L6060HST Compact Utility Tractor (A63688)
2023 Kubota...
