Loading 3520 on trailer
/ Loading 3520 on trailer #1
LHS Inc
Gold Member
Eastern Shore, Maryland
JD 3520 eHydro w/300CX FEL
I'll be spreading 1 ton of lime and 300 lbs of fert tomorrow with my 3520 and I want to carry everything in one trip. I had to buy 40 bags of 50 lb lime and 6 bags of 50 fert and I can't fit it all on the trailer with the tractor. I was thinking of filling up the spreader with about half the lime and whatever the bucket will hold. I should be able to carry the rest on the trailer. I'm not going to put any in the bed of the truck, I can't stand to see a truck sagged down in the back.
My question is one of safety. With the bucket loaded and the spreader loaded should I back on the trailer or drive forward. I'm guessing about 800-900 lbs on the back and the bucket would be 200-250 lbs. Trailer is rated for 10,000 lbs. Thanks.
/ Loading 3520 on trailer #2
Depending upon your trailer length, pull truck & hitch type - it probably does'nt make much difference. You should be well within the confines of a 10k trailer with room to spare if the trailer does not weigh more than 3k.
/ Loading 3520 on trailer #3
The key is the combination of your truck, hitch and trailer specs. What size truck, what class and type of hitch, what type of trailer do you have? Then make sure you position your load so that you are within your truck, hitch and trailer maximum trailer and tongue weight specifications.
Trailer Hitch Classes
If you have a one ton truck and a gooseneck hitch you should not have any problem pulling a loaded 3520 on a 10000 GTW trailer.
If you have a 1/2 ton truck and a rear receiver or step bumper, well I'd say you don't have enough truck and hitch capacity to safely pull your intended load.
/ Loading 3520 on trailer #4
However you load the trailer make sure you have sufficient tongue weight. If you have to little or none the trailer will start to fishtail. From somebody who has learned his lesson it's not a fun time especially if the truck and trailer are similar weights. You don't know who's in charge the truck or trailer.
/ Loading 3520 on trailer #5
I can't tell you for your exact set up (to your question fwd or backward). If you can back on and then still keep the majority of the weight over the axles and keep your tongue weight correct I would do that. Twice I have seen someone going foward up the ramps with a heavy rear and end up looking straight at the sky...
/ Loading 3520 on trailer #6
Best thing to do is pull it on one way and see how much it drops, turn it around and see how much it drops. Then pick between the two.
Or load all the bags onto the front of the trailer, pull the tractor on, set the bucket on tops of the bags.
As for a sagging truck, get some air helper springs in the future, not a bad investment if you do a lot of heavy towing in the first place.
Either way, measure the drop of your bumper just to see which way balances the load the best.
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2022 EZ-GO ELITE...
Caterpillar D4D Tractor Service Manuals (A63117)
Caterpillar D4D...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
2 Horse Trailer (A62613)
2 Horse Trailer...
WINCO PTO GENERATOR ON SINGLE AXLE TRAILER (A63291)
WINCO PTO...
