Are Bobcats Powder Coated or Painted?
   / Are Bobcats Powder Coated or Painted? #1
gumshu
JD 2025R TLB, Kubota L4802 and Can Am Defender HD7
With the few scrapes amd scratches I have on my CT235, I can't see any primer under the paint. A recent battery acid spill also removed the paint from the front lower grill whcih peeled away... also with no sign of any primer.
The primer is obvious on my Kubota. Does anyone know about the Bobcats?
   / Are Bobcats Powder Coated or Painted? #2
It appears to be paint to me, if it was powder coated I think the coating would be a little thicker and tougher
   / Are Bobcats Powder Coated or Painted? #3
Might be primer-less paint.
One way to tell if they should have primed it first is to see if the paint peels off in sheets. If it does, they screwed up. If it sticks to the metal and you can only pick bits and pieces off at a time, it's primerless.
   / Are Bobcats Powder Coated or Painted? #4
I don't know, but I can see orange in the eyelets of my lift arms!
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2015 Ford F-250 Knapheide Service Truck (A53422)
2015 Ford F-250...
Komatsu Midi Excavator (A55851)
Komatsu Midi...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2023 WESSEX RMX500 LOT NUMBER 44 (A53084)
2023 WESSEX RMX500...
