straightening a threaded rod
/ straightening a threaded rod #21
I think Spyder is right on with the straightening method. I doubt that this rod has any temper as there is not reason for temper on it. It is likely just a piece of rolled steel with a threaded end that you could get made at any machine shop and then weld the top yoke from the old one to it. If you cant get it straighten, try taking it to a shop and have them thread you a piece of cold rolled with the same pitch thread. They could weld it on to the top yoke for you also if dont have the skills or equipment to do it yourself.
/ straightening a threaded rod #22
Ive cut and pasted when the thread was too bent. Of the ones Ive pasted, or just straightened, none had failed in the 1st place - but had been damaged by side forces. The ones straightened have not been re damaged or failed in use or been damaged in any way by their use as a link. They do what they were designed for. These things can be fixed in the time it takes to find and acquire a replacement.
larry
the side link on my yanmar 1700 was bent. i heated and straightened it. lasted about a year before it broke while i was hauling sand in a 3pt scoop.. left me stranded in t he middle of working on t he footer for my house.. had to run to town and get a generic turnbuckle and some ends and weld something up.
when a got a ford 2n with t he same damage.. i cut and pasted.. it has yet to ever break... 8? ys later...
soundguy
/ straightening a threaded rod #23
sounds like a great candidate for allthread or similar.
soundguy
/ straightening a threaded rod #24
soundguy
OK. Maybe it was too bent. Maybe not the right heat. Maybe the yanmars have links with zero performance margin and thats why it bent in the first place. Gotta pick your battles. I havnt had trouble on repairs over about six years. If I did I would give some critical inspection and thot to determine how I misjudged.
larry
/ straightening a threaded rod #25
:)Thanks, but Im betting it is a big jump between it and std allthread. I stretched some allthread with moderate torque once and that woke me right up! The link is probably Gr 5 equivalent. To preserve its properties while preventing cracking at the thread roots you want to staybelow around 650F. If bent enuf that the threads appear closed up it should be replaced because it will crack at the roots unless overheated [to red] and that much heat will definitely compromise the metal properties.
larry
/ straightening a threaded rod #26
larry
to be honest, the metal in the yanmar side link did not impress me.. it looked very porous.. like bad pot metal.. had the powdery oxide you see on junk metal. i thought this odd, since I was thinking jap metalurgy.. even in 79 was pretty advanced.
contrast that with the fairly even good looking steel on the 46 ford.. it was just an odd situation.. still after the break on the yanmar, i didn't take the chance on the ford.. I was using it for the same deal.. scooping dirt.
guess the factory worker making the batch of metal that day took a break and let someone else mix that pour that day my sidelink was made... :)
soundguy
/ straightening a threaded rod #27
Perhaps you need a new used one. I think there is a place to put a want ad on this TBN site. You would be asking for one from a guy who replaced his with a hydraulic one. There must be a few laying around under guys benches, right?
/ straightening a threaded rod #28
Sure. I got a bent one I straightened. ;)
/ straightening a threaded rod #29
probably cheaper to hit a tsc or farm store.. buy their generic turn buckle, and then weld the 2 correct knuckle ends on it you need. probably salvage the ones from the oem lift link. that's what I did on my yannie.. 2-3Xbeefier than the original, and fit perfectly... not expensive either..
soundguy
/ straightening a threaded rod #30
I would disassemble the part and use a piece of pipe over the threaded portion to straighten it. You can feel the yield point when it starts to move at constant force.
If you want to replace the allthread McMaster and Fastenal have the high grade stuff.
/ straightening a threaded rod #31
I bent the top link on my DK35 yesterday while mowing with my rotary mower. I took it with me today when I went to get the filters for my upcoming 50 hr service thinking the dealer might have the right hand threaded part that I had bent.
I was amazed how he straightened it on his press in about 1 minute. No heating, he just supported the non-threaded end and cylinder on two small metal blocks and used an small aluminum block over the threads where he pressed it. Did one operation with the press, eye-balled it, did one more press, and it was straight. Then he used a triangular file to touch up the one thread that was damaged.
My Kioti dealer is also a machine shop (Timberstar in Vernon) so they are used to doing that type of work. But it is really neat to see how easy it is for people who have the skills. It's no big deal to them. I imagine it is the same for spyderlk.
/ straightening a threaded rod #32
:thumbsup: Yeah. Im guessing your bend was not severe? - lo straightening risk. Do you know what happened to make it bend? Im asking because if it bent from compressive force [buckling] it would be termed more a failure since this is a normal function called upon in use. If it bent from accidental side force I would call it damage. Id rather be fixing the accident, but upgrading the failure. See what I mean?
I will always use heat when straightening any non trivial threaded part that is bent enuf to impede a nut. The reason is notch strain. Virtually all bending movement takes place in the very small area at the bottoms of the threads - an extremely intense situation when you think about it. Heat eases the abuse by softening things up a bit. The harmless limit is around 600F. This is where shiny steel colors blue/purple. A straw-brown color precedes this, occuring around 400F. Any heat helps. The colder the metal the more difficult and abusive bending is. Threads/notches are just a worst case.
larry
/ straightening a threaded rod #33
I wonder how the OP (ducks13) made out with his repair/replacement?
/ straightening a threaded rod #34
larry
I'm quite sure I bent it with compressive force, likely transitioning at the bottom of a sharp rise. That is, going from flat to rising or even straddling a concave section. It's a fairly tough 4' mower and does not move side to side. I mow some steep, winding, and rocky walking paths.
The link that came with the DK35 is longer and thinner than the one I previously used with my old L275 DT. I will leave one of my old heavier links on the rotary mower. I'll likely make a similar modification.
It is a quite tough (and ugly) International Machinery mower from China and has a plate that swivels at the top link attachment that has two arms attaching to the rear of the mower to provide some up/down play of the rear of the deck. But I guess not enough play for my use.
I saw on another thread where someone had replaced the two bars that support the rear of the mower with chains, thus allowing more movement when the rear wheel must move higher as in a concave situation.
I did some equally mindless, and more expensive, damage last year when mowing with my Kubota L275 and going over a rounded hump. The mower lowered enough that the driveshaft contacted the drawbar, severing the driveshaft guard. That won't happen on this Kioti--as long as I remember to remove the shackel that I normally have in the drawbar.:D
There was very little bend in the threaded part of the top link and it was barely noticeable by eye and a bit of damage on about 1/8" of one thread.
/ straightening a threaded rod #35
ditto that.. hard allthread is a nice thing to have in the shop when making things.
can order from fastenal too.
soundguy
/ straightening a threaded rod #36
Compressive failure is heavy duty:eek:, and can surely happen as you describe. When I see damage to a thread tho I suspect a side thrust was present. Some lost motion swivels will not let the link swing thru. I have one on my flail like that. The threads are bumped at full swivel trying to bend the link a little. At that point the link goes into compression and the whole 3ph assembly rises. If its driven all the way to the top stop something definitely will give. Sometimes even before the stop with weaker links experiencing compression and sidethrust.
larry
I decided what with various people talking of the ease of straightening this with press etc. that I would take to the only good machine shop in town that I've found. $92 later I have it fixed I believe. Not as clear on how he did it and stuff as I'd like, I had my sick 4 year old with me when I picked it up so I didn't have time to thoroughly understand and it isn't fixed quite like I'd hoped when I took it in but it seems like a good repair and the guy knows what he is doing. They mostly work on heavy engine, I found them after asking the Onan parts department who they used after being disappointed with two shop I'd used so far trying to get my B43 Onan cam bearings in right.
Anyway, he said the threads were bad in the casting, perhaps I screwed them up in my first strightening attempt, and that they were metric threads and he didn't have metric helicoils but it just so happened that 20 mm thread is 10 tps just like a .75" english thread. So he put in the .75" helicoil and turned down the shaft about 0.030 to get it down to .75 and then recut the thread. A lot more involved than I had hoped. I still don't know how he got it straight enough to get it apart but he said that there was still a little kink in it that turning it down got rid of. I'll put in on tomorrow and see how it work but all seems fine.
This machine shop is kind of surprising to me. When I came in there before they guy was making a part for a heavy truck automatic transmission. I as amazed that they could make a part cheaper than buying a new one. He probably spent 15-20 minutes on my cam bearing problem and didn't charge me anything so the $90 wasn't so bad.
/ straightening a threaded rod #38
wow.. i'd have welded a 2" coupler nut to the top after trimming, then ground for contour, then transplanted some hard ( gr5 ) allthread ( fastenal , mcmaster car.. ) to the rod, and been done with it for under 20$ and some rod and electricity... and not worried about a helicoil.
BTDT with this type of transplant repair.. never have regretted it or had one let go.
have had straightened threads break on me though, as was stated in a prev message..
good luck
soundguy
/ straightening a threaded rod #39
Glad to read it's squared away and I hope it holds up for you!
Good jobbing machine shops are usually pretty small (low overhead) and very flexible (hence the lower cost for that heavy truck tranny part). They can also be great for reverse-engineering.
/ straightening a threaded rod #40
I hope it works for you. Regardless of skill in application, a helicoil does not make an optimum working thread. Virtually continuous load changes and dirt are issues. It is a good fastener thread where you tighten it good and forget it.
larry
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2012 International MaxxForce (A62180)
2012 International...
Pile Hammer (A62183)
2019 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
