dex3361
Elite Member
- Joined
- Aug 22, 2008
- Messages
- 3,551
- Location
- N. of Charleston WV
- Tractor
- Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
The only thing I'd worry about changing rod dia from 30mm to 1.250 would be the one cyl will be carrying more load (6.5%) when retracting (holding bucket full of material)......would this stress the FEL frame..??....Maybe/Maybe not..??
If a rod dia is changed then you'd be wise to do both...
If I swap cylinders I will swap both at the same time. I think it would be a bad Idea to have to different cylinders. Thanks.
