Superduty gooseneck question
/ Superduty gooseneck question #21
I bought a chassis/cab and added an aluminum flat bed with trap door and goose hitch below - would do it again - would do it again with a CHEVVY, though it is possible with a (removed).
It works out real good.
FULL WIDTH bed, none of that 4ft and an inch or two between wheel wells nonsense.
No tin box top rails to worry about scratching up with the goose trailer, etc.
GREAT thing about it is that it is only about 4 inches lower than a standard loading dock, so picking up FULL SIZED things at loading docks is easy.
Add stake sides if you want/need to.
Yeah, I'd do it again - Chev/GM again that is (-:
/ Superduty gooseneck question #22
I really looked at going flatbed, but you can't throw junk in the back, it wanders off on the first turn.
/ Superduty gooseneck question #23
what about stake pockets with small side baords that are easilly removed? that and some recessed d-rings and straps that live in a tool box could make for a dual purpose setup.
soundguy
/ Superduty gooseneck question #24
How is that a BAD thing ?
Junk is junk, right ?
/ Superduty gooseneck question #25
soundguy
Mine has stake pockets and a rub rail all the way around outside those.
I went to some length to make up stackable side boards out of 5/4 6 inch PT decking that I could slot in 1, 2 or 3 high according to whether I wanted HIGH for carrying a lot of stuff, medium for stuff with the trailer on, or low for just a few small items.
It worked, I wrecked a few, most stuff now gets held on with cargo straps or bungie cords.
I didn't find D-rings necessary, the stake pockets and rub rail make for good securing points.
Good enough for hauling things like my Harley Rake home, now THAT was a trip that I was pleased I had a 7ft + wide clear flat bed for.
/ Superduty gooseneck question #26
yep.. the rub ral does kind of make the d-rings a tad bit unecescary.
soudnguy
2015 New Holland 560 Round Baler  5x6 Bales (A63688)
2015 New Holland...
2023 Schulte FX3118 Batwing Mower (A66285)
2023 Schulte...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
2022 Blue Diamond Brush Cutter (A64126)
2022 Blue Diamond...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
2019 John Deere 460E 46 Ton Articulated Dump Truck (A64194)
2019 John Deere...
